Results 1 to 22 of 22
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    Offset - will ET+35 18"x8" fit nicely on a B7 S4
    Hi there. I am buying some wheels for winters on my B7. I've got 235.40.18 winter tires, so it makes sense to go 18x8 with the wheels. My question pertains to offset
    will +35 work? There's a set of RS4 reps at +35 that a local guy is selling. Stock wheels are +45 I believe, so 1 cm difference. That being said, I have NO idea what that means!
    excuse my ignorance (again) and help me out. Cheers.
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Re: Offset - will ET+35 18"x8" fit nicely on a B7 S4
    They'll fit nicely. Do it.
    Your ignorance is excused.
    Jun 02 2008
    thanks Mannuv. I appreciate the speedy reply.
    Quote Originally Posted by MOFSTEEL View Post
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    stockers are +43. +35 will look the best since the wheel will be flush with the fender. Basically, the lower the offset, the further the wheel sticks out.
    Jun 02 2008
    beauty thanks
    Quote Originally Posted by FastB7S4 View Post
    Sep 19 2007
    seattle
    learn something new everyday... so why is that?
    Mar 01 2008
    Quote Originally Posted by cellg8 View Post
    http://www.tirerack.com/wheels/tech/...jsp?techid=101
    Sep 19 2008
    2011 S4
    NoVa
    Can someone please explain to me that why these wheels that I ordered are sticking out 1/2 inch in the front for my B6 S4 then?
    http://cgi.ebay.com/ebaymotors/Parts...=p4506.c0.m245
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by s4wu View Post
    Maybe its because you bought some low quality reps and the offset is not as stated.
    I have 19x8.5 w/ ET32 and everything is flush.
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    I have 19x8.5 in 245/35/19 +35 and its super flush in the front but i feel like the rear could come out 2-3 mm. I've wanted to try spacers, but don't really want to buy them since its such a small margin... =\
    Veteran Member Four Rings JOS4AUDI's Avatar
    Jul 09 2008
    2008 RS4, 2012 S4, 2013 Allroad
    So Cal
    Quote Originally Posted by Cargo8 View Post
    I have the exact same setup and feel the exact same way but overall its almost perfect.
    Veteran Member Three Rings norsecarnut's Avatar
    Sep 15 2008
    2 Land Rovers, BMW E61 mt6
    is it ok to run staggered on quattro's?
    2008 S4 Avant mt6 Dolphin - APR Full exhaust / Escort 9500ci-stealth install / backup camera / aux-in & ipod & cd / 35% ceramic / 2" hitch class 2 / Nokian WRG2 / HID fog / Stasis high-bias center diff
    AKA: jwest
    Dec 06 2006
    staggered in what way? Different wheel widths? diameters? or just staggered offsets (like bringing our rear w/ spacers or having the offset more aggressive)
    generally speaking staggering is avoided and can cause the quattro system to detect slip when there is none, but what specifically are you talking about?
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    +1
    There has been a few threads debating the staggered setup.
    Jun 02 2008
    Does it look funny? I think the fronts at ET35 should stick out a bit....considering what my stock 18" wheels/235.40.18 tires look like now. ET35 should be 10mm further out...which is just under 1/2". Rears should be fine.
    p.s. POST PICS so we can see. I promise nobody will make fun (nobody except MofS)
    Established Member Two Rings toneloc's Avatar
    Jul 08 2008
    none
    SO/CAL
    hey was wondering is the ET on the rims somewhere?
    deval splitter.from EUROGEAR.installed by AUTOWERKS
    HRE 441R 19x8.5x35x245..thank STEVEN.
    vogtland GT coilovers.STARTUPRACING.. installed by CHARLIE
    RS4 blk optic grill n plates.. TM TUNING
    RS4 Bumper..EUROGEAR..painted installed by AUTOWERKS
    Apr 14 2004
    rs4, ruf, rs7
    L.A./Vancouver
    I'm running 19x9 et 32 and its pretty aggressive looking..fronts and rears stick out just a bit...perfect IMHO.
    Jun 02 2008
    on the back/inside...usually.
    Quote Originally Posted by toneloc View Post
    Sep 26 2006
    Southern California
    Stockers are NOT +43 they are +45. +35 on an 8" wheel will NOT make the wheel flush with the fender, it still be tucked in about 1/2". DON'T GUESS!
    Sep 26 2006
    Southern California
    Everything is NOT flush. I have seen your set up on other cars and know your fronts pass (stick out too far) the front fenders by 5mm and your backs are tucked in by 3mm. I also know why you guys with 8.5" wheels and +32 always turn your front wheel for pics - embarassment.
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    Quote Originally Posted by Fuffler View Post
    LMAOFFFFFFFFFFF
    Would you like me to take a few pics with my wheels not turned?
    ...or should I save you the embarrassment?
    Apr 14 2004
    rs4, ruf, rs7
    L.A./Vancouver
    8.5 wheel et 32...fit nice. I'm running 18x8.5 et 32 in the winter on D3's and they fit perfectly flush with the fender.
