Results 1 to 11 of 11
Thread: What to do
    Veteran Member Three Rings pa4ul's Avatar
    Mar 20 2008
    03 Audi A4 1.8T/ 72 Ford F-100
    south
    Exclamation What to do
    15mm or 17.5mm spacers on rear the front sit okay please opinions needed!
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    Re: What to do
    Is the offset 35? 10mm front / 15 rear
    2004 Moro Blue A4 1.8TQTip
    GIAC | Genesis | Forge | Magnaflow | RS4 | ABT | Sport | Premium | Cold | Dings mod ~ Painted lowers are overrated
    Want to see a fun coverband in the Philly area?
    Mar 20 2008
    south
    Re: What to do
    okay what do u mean by offset? im a noob when it comes to tire talk. Im running 245-35-19 i want the rear to stick out a little more then the front
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: What to do
    Offset has to do with the wheel not the tires. When you buy wheels they specify the bolt patter (5x112 for us), the size (18x8.5"), then the offset (the distance from the hub face to the wheel face, IIRC) Most wheels for our cars come in an offset between 35-45, the lower number being more flush with the wheel, thus pushing the wheel face out. You don't want to push it out to far or you'll run into rubbing issues with your fender. So to make an informed choice on spacers we need to know what offset your wheels are currently.
    Mar 20 2008
    south
    Re: What to do
    shit im really not 100% sure 35 would be my fair guess.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Re: What to do
    If they are 35, I wouldn't go more than a 5-8 in the rear, bringing it to an offset of 30-28. What kind of wheels do you have, were they bought for your car or where they on a different model before? You may be able to find the offset by checking with the manufacturer to be sure.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: What to do
    Quote Originally Posted by pondside36 View Post
    Close, but not quite. Offset is the distance that the hub face is offset from the centerline of the rim. So, for an et35 wheel, the hub face is 35mm closer to the outside of the rim than the center. For a negative offset rim, the hub face is further from the outside of the rim than the center line.
    -Darrick
    Jun 12 2008
    Warminster, PA
    Re: What to do
    Oh wait, I was thinking with my 17's. Yeah i wouldnt go any further than 8 or so mm in the rear.
    Mar 20 2008
    south
    Re: What to do
    okay the wheels are specifically made for audi cars. There are august union rims 19-8 . that diagram capt obvious totally confused me. but im almost positive now that there are 35. so would 15mm be about right? and how bout hubcentric or non. Im going to get the spacers from ecs so should i just buy the kit with the bolts for a little or 100 bucks or are there better deals>?
    Jun 28 2007
    AUDI A4 B6
    Germany
    Re: What to do
    What are this wheels? I wnat to get the same. They look very hot.
    Mar 20 2008
    south
    Re: What to do
    the ones i have?
