Results 1 to 7 of 7
    Jan 10 2008
    Madeira Beach, FL
    Vroom vroom then wtf? (acceleration problem)
    Okay so i've had my B6 since january had the joy of replacing three coil packs so far.. (had an mkiv jetta so i'm pretty familiar with that issue) well i've noticed about two months that a few times (and i mean like not even once a week) i'll be accelerating and then it stops accelerating and when i give it gas it does nothing, no revving at all, it's like a dead pedal.. no CEL or anything but then if i let off the pedal then push it again it's all gravy.. hmmm really odd and hard for me to figure out cause it doesn't throw a CEL. any ideas????
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    Re: Vroom vroom then wtf? (acceleration problem)
    Quote Originally Posted by geekdandpunkd View Post
    mine has had that prob... i've had it for a year and a half and it has happened maybe 4 times total. but mine does it when i turn on the cruise. cruise shuts off, dead pedal, very rough idle, mine gave a code tho.. EPC light came on and gave a code of PCM fault. shut the car off, turned it back on, and it's like nothin happened... have yet to be able to explain it let alone replicate it for a dealer.
    Established Member Two Rings smarrick's Avatar
    Apr 07 2008
    04 A4 18T 6MT QT SPORT, 07 X3, 74 Lincoln Continental
    Fort Collins, CO
    Do you have clown feet and slightly touching the brake pedal? It will cut fuel after like 3 seconds.
    Fort Collins Drinking Team Member #2
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    try cleaning the maf
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Jan 10 2008
    Madeira Beach, FL
    ROFL no i don't have clown feet lol, i drive with my toes.. i'll try the MAF cleaning tip, thanks
    May 02 2008
    2004 A4 Avant 1.8T
    Vancouver
    I had the exact same problem and found out it was a faulty brake sensor. The car would mistakenly think the brake was on and, as a safety precaution, would cut the fuel when I would accelerate. It would happen once a week. I had both sensors replaced at my local shop for about $120 (incl labor) and everything is now perfect.
    Also, my brake light was constantly on but I didn't notice it for over a month until a friend was following me.
    Hope this helps and good luck!!
    Jan 10 2008
    Madeira Beach, FL
    Quote Originally Posted by VancityA4 View Post
    that's gotta be it, i had researched about that switch and noticed that sometimes my cruise control won't work (cause the brake switch activated) so it's gotta be that.. THANK YOU!!!!
