Results 1 to 10 of 10
Thread: Weird Noise
    Sep 16 2006
    2001 Audi S4
    VA
    Weird Noise
    Hey guys, i started my car up and it started making this really bad scraping noise. I thought it was turbos immediately, and i took it for a test drive, and boost kicked in late, but it felt like only one side was bad. That being said, if they were turbos, i have a warranty through continental. Is there a way i can upgrade the turbos and parts that are damaged by paying the difference. If so, im located in northern virginia, and how would i do that. Thanks.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Weird Noise
    Is your car a tip by any chance?
    Sep 16 2006
    2001 Audi S4
    VA
    Re: Weird Noise
    No its 6 spd
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Weird Noise
    Quote Originally Posted by oxxomxxo View Post
    No its 6 spd
    I was gonna guess secondary air injector, but that's only on tips...
    You are warming up the oil before boosting, right? You will know a blown turbo when you hear it, no question about it. I'd be looking elswhere. It's a rotating metal scrapping sound? Did you pop the hood and have a look/listen yet?
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: Weird Noise
    usually an indicative feature of a blown turbo is a hella-ton of smoke coming out the exhaust
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Sep 16 2006
    2001 Audi S4
    VA
    Re: Weird Noise
    i thought if it was the turbine thats scraped up, but i tried looking but it was coming from the middle of the engine bay, and it was at night. I turned it on in the morning, no problem, i come home from work no problem, it turn it on to go out and thats when it started happening.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Weird Noise
    http://www.youtube.com/watch?v=XSEFUIcgOy0
    Hopefully that blown turbo video still works(I'm at work and can't see youtube), but that's what one sounds like.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Weird Noise
    sounds like a PS pump.. or a idler pulley IMO
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: Weird Noise
    Quote Originally Posted by jungb5s4 View Post
    That's one method of failure, I think from blown seals, but jacked up bearings will get you the loud siren.
    Sep 16 2006
    2001 Audi S4
    VA
    Re: Weird Noise
    thanks guys for the input, it was actually the water pump
