Results 1 to 7 of 7
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Is this a boost or vacum line?
    Everytime I move or touch it to adjust my "T" fitting for my boost guage all I hear is the sound of leeking air. Now I have a boost leak and I am trying to figure out if it might be from this. Let me know if it could be the problem so I can replace it tonight before I head to H2O tomorrow. Other wise I think it is my vacume line that my boost guage is spliced into. If its not a boost or vacum line then what is its purpose. Thanks in advance.
    -Rob
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Re: Is this a boost or vacum line?
    That is the brake booster. I know that much, I think it will affect boost, but dont know for sure.
    Do a search on brake booster and you will find some info on the item. I remember seeing pictures of people replacing them and how uch they paid to replace them.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jan 29 2007
    08 S4 00 S4
    MD
    That's the vacuum line for the brake booster. There are a couple of check valves inline with it as well. I had a leak there too, and yes, it will bleed boost.
    Jun 14 2007
    2000 S4
    Connecticut
    OP, I asked the same question to JaybQuick@JHM here on the boards who knows a shitload of stuff about not only the S4 but cars in general. anyways, I asked the same thing because I thought maybe I was losing boost anyways, this is what he told me..
    "The check valve is just to keep the vacuum in your brake booster so under boost you don't lose your power brakes. A bad check valve would only hurt the brake booster performance. So if there is a vaccum leak through this, it would be the booster itself. Easy check would be to cap this off and drive around and see if it works. Brakes will take more effort, but it is a free way to check it."
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    Vacuum as others have said its the brake booster hose. very easy to remove if need be,
    Veteran Member Three Rings CheesmoS4's Avatar
    Aug 24 2005
    Silver 01.5 Audi S4
    Northeastern OHIO
    can u pour seafoam down that hose, or is there a better vacum line to get into, if so can anyone show which line is the best
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Quote Originally Posted by 2k1audiS4 View Post
    -Rob
    when you car is on if that line is leaking bad you will hear it just sitting there it will sound like a whistle sound hope this helps
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
