Results 1 to 3 of 3
    Sep 21 2008
    05 B6 Sedan; 04 B6 Avant
    Derry, NH
    Need advice pls. Headlight scratches, possible to buff out?
    Hi!
    Based on the pic, do you think the scratches on the headlight lens can be buffed out? I want to buy this housing but if you think the scratch is bad, then I'll pass and wait for a good deal on a pair of xenon housings.
    Thanks in advance.
    Jun 30 2007
    Raleigh, NC
    Re: Need advice pls. Headlight scratches, possible to buff out?
    you could try filling em with clear nail polish and then sanding/super buffing them... i used to fix cd's that way, but it took FOREVER
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    I've polished my headlights 2 weeks ago...This is a very special job to do. Let me explain:
    The clear lense of our headlights is covered by a super hard coating. It may be to prevent sand blasting of the plastic. This hard coating is almost unpolishable because it's too hard. What I did is sand the hard coating until you attain the plastic lense. It's very easy to see the difference between the hard coating and the plastic. ( plastic become white with sanding). I suggest to remove the hard coating with a 400 grit sandind paper and a good pneumatic sander. after sand the plastic with a 600, wet 800, wet 1000, wet 1200, and then polish the plastic with standard rubbing compound. If you do this, you must remove all the hard coating... This is a 1 hour/ headlight if done with right tools and good worker... good luck! expect a more fragile headliht after removing the hard coating...
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
