Results 1 to 6 of 6
Thread: Big Boost leak
    Oct 30 2006
    B8 A4 Avant 6spd
    Big Boost leak
    Alright, I'm just about fed up.
    Ive been trying to hunt this leak down for the longest times now. It is a massive leak, when I get on the power it is an audible loud hiss coming from the left side of the engine.
    I have a pressure tester that I made and found every single leak the motor had. Today I completed this mod: http://www.audizine.com/forum/showthread.php?t=235106 I did 90% of it, just waiting on my Integrated Engineering plate to take out the EGR. I capped all the unused ports and clamped down the caps. Even without the EGR taken out know there's no way the leak could be coming from there. When I pressure test the motor through the throttle body, I no longer have hiss, in fact the motor holds pressure so well when I pull off the tester excess pressure is released. My pressure tester is type shitty and I can't mount it on the turbo or on the tip hence I got to go from the tb. Now that I eliminated the hoses on the engine the leak has to lie somewhere between tip and throttle body hose.
    I checked the TB hose: No rips
    Checked the IC hose: No rips
    I put in an APR silicone inlet hose and made sure everything attached to it is tight.
    I replaced the turbo outlet hose to the one off my old 98.5, had to retrofit to the old style removing the two piece dv hose. Checked for rips
    What remains is the intercooler and the actual piping in the bumper support.
    How often to oem intercoolers develop leaks?
    I wanted to try a S4 intercooler that our shop has lying around but the 2001 1.8t has a map sensor built into the housing. I visually inspected the intercooler and could not see any problems with it.
    This is a month long pain in the ass id like to finish already, any ideas/ help would be nice.
    -18 718 GTS
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    Re: Big Boost leak
    have you pressure tested your intercooler?
    2018 Navarra Blue S5 Sportback
    2001.5 Blue Raspberry S4 Avant w/ hybrids on E85
    Past Audis:
    2015 Glacier White Allroad 2.0T
    2012 Ibis White S4
    2001.5 Nogaro Blue AWE/GIAC Stage 3 S4 16,500 mi
    Fast Intentions Wide Mouth DPs and custom 3.5" exhaust
    2000 Silver A4 Avant 1.9tqm 217k mi.
    2000 T28 A4: SOLD
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: Big Boost leak
    Not as of yet, thats on my todo list for today.
    -18 718 GTS
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: Big Boost leak
    i know you say it sounds like drivers side but have you checked your DV? a bad diaphragm can cause a fairly large internal and audible leak. low boost is a symptom though.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: Big Boost leak
    I found the whore of the leak, a 1 inch long tear on the turbo outlet hose, the one I replaced, must've cracked shortly after I replaced it, out of all things. I ended up pressure testing the entire system bit by bit, while under the car I noticed the rip.
    For the first time after a month of ownership I know what the car is supposed to pull like.
    I'm set at 19psi and the car pulls stronger than a customers 2000 1.8t A4 k04 w/ j-31 (injectors fmic full exhaust) While I have the k03s a custom tune (SSP base revision 1) and a full 3" turbo back and silicone inlet pipe.
    -18 718 GTS
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Big Boost leak
    good to hear that you found it!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
