Results 1 to 9 of 9
Thread: MBC...
    Senior Member Three Rings Avant1.8BT's Avatar
    Nov 05 2006
    mycar
    MBC...
    Having trouble with my MBC. ill try to snag some pics tomorrow but was wondering if you guys could post up your mbc set ups to make sure i have all the hoses hooked up correctly and what mbc would you guys recommend?
    thanks.
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Re: MBC...
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: MBC...
    Im currently running the Vast one.
    This might help...
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: MBC...
    If you run a bleed valve you have to use it in combo with the N75. If you use a ball/spring type you can leave the N75 electrically plugged in, but use only the MBC to control boost.
    I'll see if I can't snap a pic of my Bleed type setup.
    Nov 05 2006
    mycar
    Re: MBC...
    thanks and thanks but im not running mine inline with my n75 i was told not to by unitonic.. i guess there tunes are for mbc's only
    Dec 14 2005
    Re: MBC...
    line from the turbo housing -> inlet -> line to waste gate.
    1999 Subaru Outback
    Jun 04 2007
    Austin/DFW, TX
    Re: MBC...
    Hmm, the way i have mine hooked up is that the N75 is still connected electrically with no vac hoses. The MBC is in place of the 2 other lines, is taht right?
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Re: MBC...
    I use a modshack boost machine and love it.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: MBC...
    Quote Originally Posted by biketsai View Post
    Yes if the N75 valve is no longer in the turbo inlet hose.
