Results 1 to 2 of 2
    Jun 04 2007
    atlanta GA
    Question which used ABS module
    1999.5 A4 fwd apr 93 oct 147 k
    my abs module went out....i tried the repair and messed it up. i could be successful if i did again i think but now i got a messed up module. like not repairable.
    so which year and car modules will work. i know the pump is very car specific but i'm under the impression the module. isn't. which modules will work?
    thanks
    Oct 29 2008
    '01 S4, '90 90q20V, '98 A4q
    Virginia
    Re: which used ABS module
    Quote Originally Posted by bigrobby View Post
    thanks
    You tried the electronic repair and it didn't work? Let me guess, you cut those gold wirebonds and couldn't solder to the broken wires? I can probably salvage your botched repair if you would like me to try. I normally repair these modules for around $100. Or else I have some cores sitting around and I can match your module number and see if I've got one that will work for you. Email me at [email protected]
