Here is the story,
Bought an out of state 2001.5 S4 Avant, 80,000 miles. Seller (2nd Owner) claimed the car was clean, carfax was clean...however the car was 100% in some sort of collision. Impact was front drivers door, a-pillar, wheel area.
The seller never disclosed any issues that I found on the car.
When it arrived, it needed a right rear wheel bearing, and has a somewhat severe shimmy over 50+ mph.
The seller claims that the car had bad tires and was told that was the reason for those issues. He mentioned bad tires when I purchased it, however never went in depth that these were supposedly symptoms of that. Or that they even existed.
Was installing a boost gauge in the car and under the knee bolster there was all sorts of minor damage to the relay and fuse holders. I investigated further, took it to a trusted body shop, and they found that it looks like a whole A pillar was installed (non factory welds, rust spots, misaligned body panels, etc...) Add to this the entire wheel geometry is off, which is actually causing the vibration.
E-mailed the seller, he claims no knowledge of the accident, yet now claims he knew about the shimmy and rear wheel bearing...strike one to his character.
Does anyone really know my options, I know generally used private party cars are as is/where is...however, is blatant lack of disclosure something I can go after?
There are more minor issues that the seller failed to disclose, and I believe he knew he would get away with it because he lived in a remote area of colorado where no one would be able to check the car out, and 3 plus hours from an Audi dealership.
In the end I believe all of it should be fixable, but it is not the car that the seller represented.
Let me know your thoughts...
Thanks
