Results 1 to 10 of 10
Thread: pillar removal
    Senior Member Two Rings cmorse's Avatar
    Oct 23 2006
    virginia tech
    pillar removal
    I have been searching for the past hour and cant find an answer. I need to remove the b and c plastic pillar covers inside the car. Are they clipped in like the a pillars or is there a trick to taking them out? Do I just pull on them and us a panel puller? I dont want to take a chance of breaking one. Car is a 98. Thanks
    Oct 23 2006
    virginia tech
    Re: pillar removal
    Anyone?????? I want to fix a saggy headliner this weekend and dont want to damage anything.
    Dec 30 2007
    wilmington nc
    Re: pillar removal
    Quote Originally Posted by cmorse View Post
    just grab the b pillars at the top and yank or use a screw driver all other pillars come out as well with a nice well placed yank.
    Registered Member Two Rings
    Aug 19 2007
    central oregon
    Re: pillar removal
    Just for you, a gift from me to you.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: pillar removal
    Yea, definitely don't try to remove the B-pillars from the bottom. Start at the top. Once you pop them out the first time, they get easier.
    Make sure you line up the height adjuster for the seat belt too, otherwise it can opaque the upper B-pillar piece.
    Feb 15 2004
    99.5 a4
    monroe nj
    Re: pillar removal
    you have a diagram for a and c pillars also?
    Previously: sivic
    Aug 19 2007
    central oregon
    Re: pillar removal
    yeah ill get it after school today if im not busy. just download elsawin or something if you need that many diagrams, but i will try and fit in a and c after school.
    Oct 23 2006
    virginia tech
    Re: pillar removal
    Any luck with the C pillars? Are there any screws in it and does the light have to come out first? thanks
    Oct 06 2004
    Minnesota
    Re: pillar removal
    Pull the lights out of the C pillar then just pull it off.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings boostedup's Avatar
    Sep 01 2005
    01 a4 1.8T,00 suzuki GSXR 600, 1974 Mako 171
    internationally known, Florida
    Re: pillar removal
    on my 2001 the c-pillar had 1 bolt behind the little airbag badge, then pull staight out as it has 3 metal clips holding it together, I removed my complete headliner WITHOUT removing the b-pillars, and reinstallation didn't involve removing b-pillars either kinda just slides out.
    Santorin Blue 2001.5 Audi A4 1.8turbo Quattro with Sports, Celebration, Cold Weather Packages.
    Engine:APR 93 octane. Catch Can. Air Intake/Heatsheild. 710N .
    Interior:VDO Vent Boost gauge. Short Shift. Garmin GPS. 2-10" subs. Suede interior
    Exterior:19" ASA St4's/NITTO rubber. Neuspeed Race/Bilstein Sport shocks. 15% tint. Debadge. Clear Corners. 4300K HID. MS Design Front lip
