Results 1 to 9 of 9
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    running off just the gate
    alright i need to drive my car to the shop to finish up the exhaust but dont have my ebc installed yet. Can someone tell me which line on the intake mani you run to the gate to just run off the wastegate? the turbo is 2871r internal gate.
    thanks
    ::2002 S6
    Feb 17 2005
    Sarasota, FL
    Re: running off just the gate
    You need to run a charge line (pre throttle plate) from near the turbo to the wg, NOT off the intake manifold
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    so if i tap into the hotside intercooler pipe with fitting that will work? also i left the n75 plugged in. do i loop the two that connected to the turbo and wastegate can i cap the other one?
    ::2002 S6
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    yeah that should work but make sure it's really sealed around the fitting.
    if you have a K series turbo you can just use bung on the compressor housing but i guess 2871's do not have one of those.
    {99.5 Avant}
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    can anyone post a picture of there setup?
    ::2002 S6
    Feb 17 2005
    Sarasota, FL
    The silicone hose coming off the silicone connected to the compressor is the feed line for my EBC. Keep it as close to the turbo as possible and in the hardpipe is fine, just be sure to use some pipe thread tape or some type of sealant on the fitting
    Feb 17 2005
    Sarasota, FL
    And the N75 doesnt have to be looped, that does nothing
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    Quote Originally Posted by A4ringedONE8T View Post
    alright awesome. Looks like jb weld and a barb and i should be able to fire this up tonight. im dbw and have so i have a map. would it be ok to drive without the o2 in the exhuast? i relocated the HFC to under the car and havnt welded the bungs in yet. i guess i could but would rather do it at the shop.
    ::2002 S6
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    i hate you and your no maf...
    ::2002 S6
