Results 1 to 40 of 47
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    PICS!!! of my latest problem w/ my S (Warning!!:graphic!!)
    So before the pics, I noticed this morning that I had some grease on the outer spokes of my front drivers side wheel...didn't have time to take it off before class....
    Fast-forward to 6pm after class, I remove my front drivers side wheel....
    (Yes, that is all grease)
    And here is what I find:
    CVC boot exploded/erupted into a monstrous shower of grease!!! Anyone guess the extent of the damage or how much to fix it??
    Also, should i be worried about my brake pads absorbing any of that grease??
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Sep 08 2008
    2K S4+79Merc300SD+65Barracuda
    Rohnert Park CA
    Re: PICS!!! of my latest problem w/ my S (Warning!!:graphic!!)
    Eh! Couple hundred for parts(one side)You'll know if there were any damage as a result. Clicking noise, grinding...you'll hear it most when you turn. I had a small leak and caused minor damage, but the boot kit will fix it right up...no worries.
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Looks like you need need a new CV boot my friend.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Oct 31 2007
    Grand Rapids, MI
    Yea, i figured that already, I've been told I will hear a clicking noise, but I have been getting that for the past couple weeks ONLY when I depress my brake pedal at low speeds, is that related to the CV Boot issue or no?
    MKIV BPM R32 (DD)
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Quote Originally Posted by DraxeofDclan View Post
    ?? A cv boot repair kit is around $20 tops.
    http://www.ecstuning.com/stage/edpd/...ory=Driveshaft
    the homebrew'd s4
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    I been driving all summer with a torn cv boot, I didnt hear any sounds coming from it, car still drives like normal... I think I will change it this weekend before the winter weather starts taking over...
    Aug 06 2008
    Canadia
    it will make more noise when the grease is gone.
    i would just replace the boot and load it with grease, your noise will probably go away too.
    Veteran Member Four Rings S4 John's Avatar
    Sep 19 2006
    The Man Cave
    don't wait too long. you will most likely have to replace the axel if road elements get in there. i would do it asap...
    //NEVER FOLLOW
    B5 S4 Avant - Nogaro Blue - TTE550 - ETSPEC
    8J TTRS - Panther Black - United Motorsport
    8V RS3 - Mystic Blue - TTE700 - Unitronic
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    you will hear a clicking noise if u keep driving it like that...thats not even a big problem man i just replaced my pass side and let me tell you its alot dirtier than yours... all you have to do is clean the grease, pull teh axel and do the CV kit... everyone sels em i got mine at ECS
    heres a DIY
    http://www.audiworld.com/tech/misc27.shtml
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    isn't that grease pretty nasty stuff? like a really carcinogenic grease? that's a nasty cleanup
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Jun 15 2007
    Quote Originally Posted by jungb5s4 View Post
    yea its a pain to cleannn but it still cleans
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Jul 07 2007
    Tempe, AZ
    true.. definitely wear some gloves and make sure you dont touch your face or mouth with the grease AT ALL... some good degreaser and a bunch of paper cloth and you should be good to go
    Aug 06 2008
    Canadia
    dude, its not hydrochloric acid and its no worse for you than engine oil.
    Although i do recommend gloves and not eating it, no more care needs to be taken than you do with an oil change. the shit you have to watch out for is carb clean and brake clean, the main ingredient is Xylene which is very very toxic.
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Quote Originally Posted by MacDaddy View Post
    Yeah. it's just grease LOL. BUT if you want, you could wear a full respirator and hazmat suit.
    Just make sure you walk around the house a few times before working on the car and video the neighbors reaction.
    And I wouldn't wait till this weekend... Any small rocks/pollen/sand/dirt/dry leave particles/ANYTHING gets in there and it's a PITA and you'll have to replace the half shaft.
    Oct 31 2007
    Grand Rapids, MI
    I know that it has been clicking for about 3 weeks now, you think i should just get a beefier axle from raxles.com to be safe??
    MKIV BPM R32 (DD)
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    you has diarrhea?
    SBSC
    I also like to live dangerously.
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by Overboostin View Post
    he keeps driving it like that and there's no way you want to re-use the axel. I could understand if it were new.. but if his car has mileage, it's a bad idea to just throw a new boot on it imo.
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    I lol'd.
    We now sell solid steel front axles for $125 a pop. Complete front axle and grease! Jason is finding great sources. Here: http://www.jhmotorsports.com/shop/ca...roducts_id=111 No core charge either
    Or, our front inner CV boot repair kit here: http://www.jhmotorsports.com/shop/ca...roducts_id=114
    Good luck man.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Sep 17 2008
    2001 Audi S4
    Mary Land
    cv boot grease is good for you :), just smells weird when its all over you. just got done bolting my trans back in and it looks like the upper half of my body took a cv boot grease bath.
    new boot and your good to go i imagine cheers
    EDIT: I had the link to JHM's boot kit for 30 bucks, but then i saw they had already posted it above ^^^ those axles are tempting too
    Veteran Member Three Rings nateS4's Avatar
    Apr 25 2008
    01.5 Nogaro S4 6spd, 02 GSXR, MkIII TDI
    Baltimore
    Quote Originally Posted by AMC83189 View Post
    Belkin 2+2 Gum Cutter will clean it up pretty quick
    2001.5 S4 Nogaro Stage III
    Test Pipes|AWE Twin1|Forge Hybrid BOV/BPV|JHM MBC|VAST Tuned|FrankenTurbos|034 Mounts|Hotchkis S-bars|RS4 Grille/Knob|50w HIDs|Vogland/Bilstien|JHM SS
    02 Suzuki GSXR Telefonica Movistar
    88 Bimmer E30 Vert
    98 Jetta TDI
    90 Corrado G60 Sold!
    92 Audi 100 Sold!
    http://photobucket.com/nateS4
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    buy the entire axle for 125 from JHM and a boot kit. swap in the new axle and repair yours when you have time as a spare for the other side or one to sell. cause when one goes out the other side will very soon. I changed both of mine recently, do both now or you will be cleaning up the same mess on the other side later.
    Veteran Member Three Rings TRANS4M's Avatar
    02 Imola S4
    VA
    Quote Originally Posted by infinkc View Post
    TROOF!
    I replaced my passenger side and 5 weeks later needed to do the driver side. Wish I would've caught both before the boot split in half. Clean up was a PITA!
    After you fix that, go to the other side and look for cracks!
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    the dirties of jobs.. cv boot repair.. lol at the hazmat suit
    GIAC-X, STASIS TS,VAST,034 MS
    Dec 06 2007
    Calgary, AB, Canada
    It'll take you 1 hour start to finish, $20 for a CV boot kit, and a bunch of paper towel. Done. Don't wait too long or the CV joint will be FUBAR too.
    Senior Member Three Rings Awwwjeez's Avatar
    Feb 11 2008
    2001 Silver S4 (stock for now)
    Santa Clara, CA
    that HAZMAT suit is awesome.
    Also off topic I have that same suspension. How do you like it? Does yours make a lot of noise?
    Counting cards isn't illegal. It's frowned upon... like masturbating on an airplane
    Jun 14 2007
    2000 S4
    Connecticut
    i heard its not that great just to replace the boot its just worth it to replace the axle itself...
    Oct 31 2007
    Grand Rapids, MI
    okay, my car has 66k on it, i had the passenger side outer boot repaired at vast when i got all new control arms at the end of july.....then the clicking sound started about a month after that...wish i would have replaced both......both a guy from raxles and Mike from VAST said I should be okay w/ just the boot kit. I will be driving on it all weekend but only to and from work, I am taking it in Monday.....you guys think I will be okay through the weekend and not cause any PERMANENT damage I will be driving about 100 miles top til monday??
    Isn't the labor going to be about $150-$200 more if I replace the axle vs. doing just the boot kit. I just ordered the kit from VAST for $24 shipped!!! but, don't want to have to repair something else down the road cause of this problem....Jordan and Matt, what do you guys think??
    MKIV BPM R32 (DD)
    Veteran Member Three Rings VR4-S4's Avatar
    Jan 24 2008
    2013 S6, 2000 S4
    Columbus, Ohio
    Replace the axle. Its EASY as hell to do, a lot easier than doing the boot kit. I paid 160$ for mine, now that you can get it for 125 you might as well to both sides...$600 from Audi btw per axle. You will need triple-squares to take bolts off so get them too if you don't already have a set.
    B5 S4 - PJK04's Vast E85 Tuned
    452AWHP, 475AWTQ
    C7 S6 - RS7 Turbos Vast Tuned
    B8.5 A5 - GIAC Stage 1
    B8 A4 - Stock
    Oct 31 2007
    Grand Rapids, MI
    Quote Originally Posted by blmlozz View Post
    my car has 66,52k on it, i've owned and babied it from 13k on.....i have to still drive it this weekend, but am getting it fixed first thing monday, u still think its a bad idea to just throw a boot on there??
    MKIV BPM R32 (DD)
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    Simple fix.
    Replace the boots now for $20 as a temp fix.
    Replace the axle now for ~160 and be done with the "clicking". In all honesty, you might as well replace both axles and not worry about any damages.
    I replaced both my CV boots and control arms about a month ago. My passenger side CV boot exploded all over the place as well. When I hit 105K, I too will be replacing my axles, currently at 94K.
    2015 B8 SQ5
    Click Here
    Past
    Oct 31 2007
    Grand Rapids, MI
    Yea, I just talked to jason and he said that if it is clicking that i should just be careful and replace the cv joint, so I just placed an order for the SOLID cv joint from JHM!!
    MKIV BPM R32 (DD)
    Oct 31 2007
    Grand Rapids, MI
    Quote Originally Posted by Awwwjeez View Post
    As of now, I love the GT's. when I first got 'em, I had the horrible "pogo" effect and a very sloppy ride, as 6 of my 8 control arms were bad. Once those got replaced a couple months ago, the ride is AMAZING. Corners great, no pog at all!, and it handles bumps amazing for a CO setup and my car is pretty slammed....I know that if I had stock suspension w/ my wheels, I would have blown atleast 2 tires, but the GT's saved me both times. As for noise, I can sometimes hear my springs making a "bouncing" sound when I go over speed bumps, other than that, nothing really
    How about you? Whats ur thoughts on them......any downsides??
    MKIV BPM R32 (DD)
    Veteran Member Four Rings S4 Dan's Avatar
    May 04 2005
    2000 A8, 1992 300zx, 2000 R1
    Connecticut
    Quote Originally Posted by Matt@JHM View Post
    I lol'd.
    Good luck man.
    holy crap! thats pretty much free! and theres no core charge? now thats just crazy talk.. haha
    2000 Audi S4 - Rip (Someone elses bad)
    1991 300zx TT - Rip (My Bad)
    1992 300zx - Hope I have better luck
    2000 Audi A8
    Feb 11 2008
    Santa Clara, CA
    Quote Originally Posted by 2fastS4 View Post
    Mine makes noise when it goes over speed bumps and train tracks so I was just curious if that was just mine and they weren't installed right or if thats common. I love the ride way better than stock. I think mine is a little too slammed. My passenger side front wheel rubbed a hole in my splash guard. I should have rolled my fenders cause its starting to chew my wheel a bit. Sometimes the big speed bumps I bottom out on no matter the angle or the speed I'm going.
    Oct 31 2007
    Grand Rapids, MI
    Good, I thought a shock was blown or something, glad too know not only mine make that noise as well. what is your thread at to be rubbing a whole in your wheel well?? Mine is 1" exposed thread rear, 1 1/4" upfront. What size wheels/tires you running??
    MKIV BPM R32 (DD)
    Established Member Two Rings jesterekim's Avatar
    Aug 26 2007
    2001.5 Audi S4
    New York
    Don't worry about it, I've been driving with both of my CV boots torn on the front for about 8 months. With the shot CV boots, I also had a shot tierod end. Shit made alot of noise when turning but it was fine. I finally got new axles and tierods about 2 month ago.
    Stage 2 | Brilliant Black | 6-speed
    GIAC X
    APR Stealth Catback
    APR Bi-Pipe
    Pro DFI Boost Gauge
    Veteran Member Three Rings Bimmer2Audi's Avatar
    Sep 10 2007
    2001.5 Audi S4
    G.R. Michigan
    Ryan, give me a call ASAP. We're having a meet, sunday at noon. If your S can't make it I can pick you up, if you want.
    B5 S4 6MT Stage 2+
    JFONZ GWERKS-AWE Twin 1-SSAC-JHM FMIC-H&R Springs-BBS CH's 18x8.5
    Jul 04 2007
    00 s4
    danbury
    ya i just found out i had the same problem this morning. i haven't had time either to pull it. so i'm probably going to order both jhm axles just to get it over and done with. I'll do that if warranty doesn't cover it. i'll be making my decision tomorrow morning.
    Veteran Member Four Rings Videlov's Avatar
    Jul 01 2008
    Chicago, IL, Bulgaria
    Well I read this thread earlier in the week. Odd enough I also noticed some grease on the inside and spokes of my front drivers wheel but not much. Just check it out and.... ITS RIPPED!
    I'll go ahead and read over this thread and see what I have to do. This pisses me off!
    JHM will probably do the trick!
    "Some Redbull, some water, some nice fresh house music!"
    2000 Audi S4 (Sold)
    2010 Audi S4 (Next)
    Oct 31 2007
    Grand Rapids, MI
    Quote Originally Posted by Videlov View Post
    Just do what I did, order a new outer CV joint from Jason, $94 shipped to me!!! Please note that if you continually drive on a torn outer CV boot, opposed to what many say about it ruining the entire AXLE, it will simply make the entire OUTER CV JOINT shot. Even though $125+shipping vs. $94 shipped isn't that big of a deal, if you aren't doing the install/swap yourself, getting a whole new axle to fix the problem will be alot more expensive in labor than getting the right and necessary part to fix it. Thanks again Jason for the helpful info!!
    MKIV BPM R32 (DD)
