Results 1 to 14 of 14
    Active Member Three Rings quattro47's Avatar
    Sep 22 2007
    Orange County
    Puttin Headlights In The Oven?
    Alrightt i know ive heard and seen alot of mixed reviews on putting headlights in the oven to be able to pry them apart so you can do the DIY blackout headlights.
    Give me some feedback because i was told to put it in for at the most 10minutes at a time at 200-250temp.
    Is it safee or has anyone done it?
    //B9.5 SQ5//034 Stage 2//
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    Re: Puttin Headlights In The Oven?
    yes, they will be safe. just remove the bulbs/ballasts. you will probably have to go longer and keep a hair dryer/heat gun handy.
    Oct 29 2005
    10speed
    San Francisco, CA
    I heard the broil function does wonders
    - Clint
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I would just go ahead and use the heat gun.
    I have already done this mod, three times, and the heatgun works wonders.
    -Sami-
    Sep 22 2007
    Orange County
    defiantly gladd to hear that it is safe but i tried the blow dryer and screwdriver and all that stuff following the DIY on a4mods.com...no fun!
    Mar 11 2008
    B7RS4 & e46Ms
    Quote Originally Posted by noregrets183 View Post
    blow dryer vs. heat gun are two completely different things... Get a heat gun.
    I've done this at least a dozen times with other headlights and the heat gun works fine. The oven just scares me...and I really don't see it being that much faster.
    Sep 22 2007
    Orange County
    bad proof reading i have used both heat gun and blowdryer..
    ruins the plastic trim around the headlights.
    oven i heard you can just heat up and pull apart eventually after a little of prying?
    Veteran Member Four Rings BNZ TOY's Avatar
    Oct 29 2006
    1G FX35, 03 R6, B6 A4 MT6
    Vancouver
    just a thought, take your time... I can see this turning out disasterous if the heat is too high in your oven. If you notice the heatgun ruining the trim around the headlight, you are rushing or putting the heatgun too close to the housing.
    Another silver B6
    Go/Stop: K04-015 ~ Intake/TIP ~ Forge Splitter ~ Neuspeed turboback ~ B&M SS ~ H&R Sport w Bilsteins ~ S4 Sways ~ Eurocode FMIC ~ 245 Rotors/18z ~ FX300 240mm LWFW ~ Snow Meth Inj ~ EURODYNE tune
    Flair: USP Front ~ Cupra R ~ S4 Trunklip ~ Euro Roof Lip ~ VMR v710 235/19/35 ~ S4 doorblades ~ B7 rear valance ~ LED fogs ~ B7 DTM skirts ~ Euro RS4 Steering Wheel ~ S4 Recaros
    Veteran Member Four Rings 3.0L AUDI A4's Avatar
    2004 A4
    Central Jersey
    DO NOT PUT AUDI HEADLIGHTS IN AN OVEN!!!!!!!!!!!!!
    This is not the propper way to do this. You need to use a heat gun and take your time. The plastic audi uses for their headlights will melt in an oven.
    If you are worried about ruining the plastic anyway, THIS MOD IS NOT FOR YOU. To seperate these headlights you need to pry**** the housings apart. Whenever you "pry" something it never looks the same..
    You are better off spending money on E-Codes.
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Quote Originally Posted by 3.0L AUDI A4 View Post
    +1... and BTW this mod is not fun at all... this mod suck to do and yes the trim will be destroyed and oven works for a lot of headlight but not four our cars... sorry! Joey mods is a pitta to do!
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    I suggest setting the oven to 450 degrees and then buying ecodes.
    -Matt
    FCDT Member #1
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by mdzaudi View Post
    For what? To kill the salmonella?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    May 01 2008
    Winter
    450F for 3 hours, blacked out headlight guaranteed!! easy way!
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by davidlizard View Post
    Actually, it maybe liquid by then. 3 hours? That's like roasting a turkey, bro!
    USP Member 110
