Results 1 to 6 of 6
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    Driving with "spare"
    So my car is in upstate NY after a little run in with a curb. My question is, I currently have 3 aftermarket wheels (petrol vengeance) and a stocker on. The aftermarket wheels are wrapped in a BFG KW2's and the stock Avus rim has a conti sport. Is it safe to drive the car almost 300 miles to my dealer with the mis-matched rims/tires?
    Also, the car still has lot of work to be back to pristine condition including a 4 wheel alignment. Will driving with 3 matching wheels and the "spare" ruin my tires?
    B6 S4 Avant: Nogaro / JHM Tuned/ Piggied / Milltek Non-Res / JHM SS Trio / Hardwired V1 / SS Brake Lines / CC Mod / Stern Snub / LED License Plate / 18" TSW Vengeance / 20% Tint / DIY Blackout Grill / Black Window Trim / Thule Bike-Ski-Fishing Pole Rack / Full Timing Chain at 68k oh wel...
    Jan 24 2008
    West Coast
    Re: Driving with "spare"
    If they're all the same size - height/width, you shouldn't have any issues... It's when you change up the wheel sizes that significant problems can occur.
    How's tread life on all the wheels? Over the long haul, that could cause problems, but over 300 miles - probably not.
    Moderator
    Senior Member Three Rings mitchholmstrom's Avatar
    Jun 22 2008
    Audi B6 S4
    anaheim hills, ca
    My spare sits in my buddies garage... collecting dust.
    2005 Audi
    :: Mods ::
    : Devries National - Stage 1 Weight Reduction
    : Euro Plate = Z3KS S4 - 08/08
    : Valentine One - 06/08
    : Painted Gloss Black Upper and Lower Front Grill - 09/08
    : Painted Flat Black Wheels - 09/08
    : RS4 Rear Swaybar - 10/08
    *OPEN FOR SPONSOR*
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    What are the tire profile / dimensions and hte wheel dimensions?
    I know that the stock 18" (split seven spoke) wheel with the stock Contis are the same ROLLING diameter as my 19" BBS CH BEs with 245/35/19 tires. if the profile of the tire goes down (low profile tire) the rolling diameter could be the same and it would be all good, no problem.
    Apr 23 2008
    B6 S4 Thunder Wagon
    3/4 Rims (Petrol Vengeance) are 18x8 running a 235/40/ XL. I think the stock Avus has a ContiSport 235/40/18 XL. I think I should be alright, I pick up tomorrow morning and should have it at my preferred dealer before service closes at 5.
    Aug 18 2008
    SoVA
    overall diameter is the only thing you need to worry about. as long as your spare is within 4% of the overall diameter of the existing wheels you will be good.
    here's a calculator that will allow you to compare different wheels:
    http://www.1010tires.com/TireSizeCal...?action=submit
