Results 1 to 11 of 11
    Dec 31 2006
    boston, ma
    requested=actual boost, still not hitting 21
    im fluttering around 17-19, did some runs and with vagcom and requested and actual boost are good, i was suggested a maf was the culprit...im apr 1+, does this sound right?
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    Re: requested=actual boost, still not hitting 21
    yes... apr's file isn't as aggressive as some others..that sounds right
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Can you post up the boost log.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Dec 31 2006
    boston, ma
    Quote Originally Posted by audikid66 View Post
    i wasnt asking if my boost was right...apr does hit 21, ive done it..i was asking if the maf could be the problem
    Dec 31 2006
    boston, ma
    Quote Originally Posted by actlsub9 View Post
    had it done at a shop..so dont have the results
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    Check out post #23 on the following thread, 400HPA4 posted some good things to check.
    http://www.audizine.com/forum/showthread.php?t=234539
    Veteran Member Four Rings a4000's Avatar
    Nov 30 2004
    Pittsburgh
    Had same problem here until I replaced my stock dv.
    '17 Audi S8 plus // DS1 // E40 // SRM TCU // SRM Flex // SRM Manifolds // SRM 3" Intakes // 034 HPFP // ARM Downpipes // Milltek Non-Res // Ibis // Black with Arras Red Stitching // Dynamic Package // Bang & Olufsen // Black Optics // Driver Assistance // Cold Weather // CETE ASC // 21x9 Ferrada FR8 // PS4S
    '19 Q7 3.0T Prestige // Audi Design Selection Murillo Brown // Luxury // B&O // Black Optics // Adaptive Chassis // Cold Weather // Tow // Night Vision
    Dec 31 2006
    boston, ma
    Quote Originally Posted by a4000 View Post
    you logged and your requested boost was the same as actual boost?
    Dec 18 2007
    nj
    you only going to get what is requested, this is based on the map they used in the flash. your MAP sensor only tells you what the pressure in the system is, it's not going to tell it to request less. but hell, i've been wrong more then once before :P
    Dec 31 2006
    boston, ma
    all im saying is that since the actual and request is the same...that would rule out a leak right?
    Dec 18 2007
    nj
    yes, it would.
    the ECU is using a static map to determine what the requested boost should be, i don't know exactly what this is based off of (RPM + Engine Load?) but it should not just change.
    Maybe he was overboosting before?
