Results 1 to 8 of 8
    Jun 09 2008
    BIG O TURBO A4
    North east NH
    full built 2.0/gt35r tune questions???
    my name is myles im in the middle of duing a built aeb 2.0 i have a gt35r with 630cc injectors the only thing i dont have covered is the tune on of my friends have mrc and still have many miss fires as soon as he hits 28psi so in other words if u guys could give me some info and ideas wat to run for software that would be fantastic.
    thanks
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: full built 2.0/gt35r tune questions???
    Moving to tech talk.
    Lots of guys here can answer this one better than me.
    Jim
    I Do Werk.
    Dec 05 2007
    Depending on what tune you go with will determine what size injectors you would be using (the tuner will tell you what you would need to run thier tune). Misfires are mostly due to spark plugs (not gapped correctly for BAT applications) and ignition coils. I think for your application, the gaps for the plugs would be around ~.026". Or you could just use the Bosch f6dtc which is pregapped (does not need gapping) which is one step colder than OEM plugs and can run to about 25k before needing replacement.
    There are others whom know way more than I, and I learn off of them. So, they should be able to grant more info than I can. They should chimme in soon.
    Jan 25 2006
    A4 2.0T
    MD
    28 psi is a lot of boost.
    Veteran Member Three Rings killa's Avatar
    Sep 23 2006
    500whp A2 vw 16v gti, 97 Audi
    Jersey
    1000cc injectors to take advantage of that turbo, 630's will max out around low 400's at the wheels.
    Bad Ass I Beam rods are finally here. Join the Brute Revolution
    My Car is for sale, click here:http://www.audizine.com/classifieds/...?product=39888
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by killa View Post
    indeed.
    Jun 09 2008
    BIG O TURBO A4
    North east NH
    i think im going to run the 1000cc injectors with 034 stage 2 efi
    and my car is a 98 so it is already drive by cable
    [URL="http://www.034motorsport.com/product_info.php?cPath=22_41&products_id=399"]
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    034 actually has a few files of mine on their site for the IIc using 800cc injectors with a 2 liter and GT35r.
