Results 1 to 7 of 7
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    *** Wheel Stud and Nut Kit ***
    Tired of hitting the inside of your wheels against the rotors?I know I am....
    Wheel nut and stud combo, M14x1.5 threads, Grade 8.8 with Zinc plating. Supplied in 2 lengths, default is 1.75" (which is fine for most wheel applicaitons w/o a spacer), or 2.5" which would accomodate a spacer. Fits many Audi application with M14 threaded hubs, cone seat for most aftermarket wheels.
    For 1.75" stud, lower threads are .4" (10mm) long, upper threads are 1.2" (30mm) long
    For 2.5" stud, lower threads are .4" (10mm) long, upper threads are 1.7" (43mm) long
    Price for STUDS + CONE SEAT NUTS = 79US SHIPPED
    Price for STUDS + BALL SEATS NUTS = 88US SHIPPED
    Send me a Private Message when you are ready to order.
    Thank You!
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Re: *** Wheel Stud and Nut Kit ***
    That's not the best price but these are absolutely worth the purchase. You won't have to have different length bolts when changing spacer sizes!
    Feb 26 2006
    Earth
    I have yet to find a better price...
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    how much if we wanted both the ball and cone seat lug nuts? can you hook up a special price?
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    What exa tly do these do now?
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Quote Originally Posted by Cargo8 View Post
    Instead of putting on a balancing act trying to hold the wheel on the hub with one hand while trying to align the lugnut with the other hand, these will act as studs and you can slip the wheel on these, and use nuts like in most american cars.
    Feb 26 2006
    Earth
    All PM's replied to.
