    Senior Member Three Rings 4 black rings's Avatar
    Mar 11 2008
    West Menlo, California
    What is a COOLING MIST WATER/METH?
    What does a kit usually run in price and some pictures of installs would be great. And where can you pick one up? Thanks
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    Re: What is a COOLING MIST WATER/METH?
    I paid $275 for stage 1. Stage 1 is a vacuum line attaches to a sensor and you adjust at what psi the meth should spray. I found this just fine for my needs.
    The install isn't pretty.. however it's hidden. I've got all the wiring hidden under the cover at the top of the bay where the battery/ecu is. The pump itself is mounted behind the bumper next to the lower windshield fluid container. I used the windshield fluid resevoir as my tank.
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Veteran Member Four Rings Slo.Mo.Shun.'s Avatar
    Oct 14 2006
    MK6 Jetta
    South,FL
    Mine is mounted in the trunk, and the pump its mounted by the rear wheel well. I do have the tank in the trunk, but most people dont have a clue.
    -Unitronics Stage 2+ ECU/TCU tune.
    -EI AL CAI.
    -Driver Mod.
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    i have my tank where the sat radio unit would go.. (cabinet on left hand side) with the pump under it.. i probably have the cleanest install around as far as meth goes... i believe it cost me 329 and a bitch worth of labor, running lines from the trunk to the engine compartment, but is it worth it? hell fuck yeah!
    heres my write up and dynos and PICS :)
    http://www.audizine.com/forum/showth...t=water%2Fmeth
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    Veteran Member Three Rings matttl16's Avatar
    Feb 25 2007
    2007 audi a4 and 2010 audi a3
    phoenix az
    i have mine installed in the engine bay with a custome bracket right next to the windshield wiper tank... and the tank is sued for the water/meth
    07 b7 a4 2.0t stage 3
