Today I got my injectors back.. results were somewhat interesting (in order from 1 trough 6 separated by commas) ALL TESTS DONE AT 43.5 PSI:
RESISTANCE: 14.3, 14.4, 14.3, 14.4, 14.5, 14.4
PRE CLEANING SPRAY PATTERN: GOOD, GOOD, FAIR, GOOD, GOOD, GOOD
POST CLREANING SPRAY PATTERN: ALL GOOD
PRE CLEANING STATIC FLOW IN CC: 95.5, 93, 92.5, 96, 95.5, 96.5
POST CLEANING STATIC FLOW IN CC: 96, 95, 95, 96, 95.5, 96.5
PRE CLEANING PULSED FLOW IN CC: 97, 95.5, 94, 98, 97.5, 98
POST CLEANING PULSED FLOW IN CC: 98, 97.5, 97, 98, 97.5, 98
CC/MIN @ 43.5 PSI: 288, 285, 285, 288, 286.5, 289.5
PRE CLEANING INJECTOR BALANCE: 4.1% of each other
POST CLEANING INJECTOR BALANCE: 1.0% of each other
TESTING FLUID TEMPERATURE: 71F
So yeah, the cleaning improved injectors 1, 2, and 3 big time.. the rest improved by very little. The only thing I would have done differenlty is specify the pressure I wanted them to test them at... our cars have a 4 bar pressure regulator.. 4 bars is 58psi. Ohh well, next time I have injectors cleaned I'll make sure to tell them to crank the pressure up to what the car actually uses them at. Improvements were noticed though across the board... was it a waste of $118.00? I dont think so.
