Results 1 to 12 of 12
    Registered Member Two Rings tontod's Avatar
    Nov 12 2005
    99.5 Audi A4 1.8T quattro
    MA
    CEL - System too Lean
    I had a leaky valve cover gasket, and not long after replacing it I got this:
    17544 - Fuel Trim Bank 1 (Add): System too Lean
    P1136-35-10 --- Intermittent
    I get some hesitation under hard acceleration, especially going uphill
    I have the PES T28 kit, 2.25" borla exhaust, carbonio CAI
    What should I do? Thanks.
    Feb 17 2005
    Sarasota, FL
    Re: CEL - System too Lean
    Boost/vac leak would be the first thing I would check
    Nov 12 2005
    MA
    Ok, thanks.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Quote Originally Posted by tontod View Post
    Ok, thanks.
    Can you please let us know if you do find a boost leak? I'm going through an issue at the moment with my PES tune also.
    Nov 12 2005
    MA
    I will. Though, I'm not sure when I'll get a chance, I'm going on travel end of this week.
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Maf, Whens The Last Time You Changed It.
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Nov 12 2005
    MA
    The MAF has never been replaced as far as I am aware.
    Veteran Member Four Rings SFexBOY's Avatar
    Feb 25 2004
    1990 BMW 325iX
    Staten Island, NY
    most likely MAF. Got that a while back, swapped a new one in...presto...fixed.
    '90 BMW 325i...SOLD!
    '89 BMW 325ix...SOLD!
    '05 BMW M3
    01.5 A4 1.8TQ (175K, owner since 4K)
    My cars.
    Nov 12 2005
    MA
    I'll get it taken a look at this Friday.
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    I have a pes tune as well and when i got that code it was a vacuum leak...
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Nov 12 2005
    MA
    My MAF @ idle = ~3.5 g/s. Is that a normal reading?
    Nov 12 2005
    MA
    The problem turned out to be bad wiring to the MAF. Also, the ICM wasnt bolted down properly due to it having to be relocated because of the carbonio CAI.
