Page 1 of 5 123 ... LastLast
Results 1 to 40 of 187
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    My motor build...
    Threads related to my build:
    Main thread: http://www.audizine.com/forum/showthread.php?t=214216
    piston ring gapping info http://www.audizine.com/forum/showthread.php?t=224946
    misfire problem http://www.audizine.com/forum/showthread.php?t=234049
    Current Specs on the car:
    Monitoring
    Apexi avc-r EBC
    Innovative wideband
    Prosport boot 25/30 boot guage
    suspension
    Blisten Shocks, Neuspeed springs
    H-sport swaybars
    Oette wheels
    034 motor, tranny, snub mounts, and rear diff inserts
    Motor
    SCAT rods
    034 coated main and rod bearings
    ARP main bolts
    oem piston rings gapped for BT
    Supertech exhaust valves
    Force-fed
    GT3071r Turbocharger
    Tial 38mm wastegate
    SPA manifold
    Tapp tune
    Lightning maf
    Garret Large FMIC from 034
    Fuel delivery
    Bosch brk7e spark plugs
    630cc seimens injectors
    034 Adjustable FPR
    034 Fuel Pressure gauge
    Walbro 255 highflow fuel pump
    Tranmission
    Fidanza 9lb lwfw
    Southbend stg5 clutch
    k0mpressed's 20/80 center diff mod
    Problems occured:
    Waiting for parts (make sure you have it all before you start!)
    Idle issue, caused by leaky intake, and loose bolts on the TB
    Head demolitoin: I learned the hard way that you NEED to use loctite on that crank bolt or else it WILL losen and destroy about 16 valves or so.
    Misfire: caused by slightly bent intake valve that would seal itself up fine, and bad valve seals.
    Im going to unify my threads into one nice build up in this thread when i get more time...
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: My motor build...
    The beginning
    Day of pulling the motor
    Getting to work
    After a long day of work
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    The tear down
    Accesories off, head off
    The cause of a lot of drive train slack
    dirtay pistons
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    During downtime, I found some time to become creative
    showing off the 3" TB and the difference between a 3071r and a k03
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    Man come on...post up more pictures!
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    She found some new shoes in her downtime
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    pistons back in with SCAT rods, 034 main bearings, and 034 rod bearings. Accesories also ging back on
    Head back on, and more accesories
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Tranny back on with Southbend stg5 clutch, fidanza 9lb flywheel, and 20/80 center diff mod.
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Finding her home
    All in, just need to do incercooler piping
    Jan 25 2006
    A4 2.0T
    MD
    How do you feel about that 9lb flywheel?
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    How she sits now
    034 fp guage
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    After she was running for a couple weeks, the bolt on my cam gear sprocket losened and my origonal head went bye bye, bending about 16valves. So i purchased a head which was form a car that was "running" when it was pulled. One week after purchase the head arrives to have this problem
    Got the the exhaust valves upgraded to supertechs by a euro tuning shop down here only for them to fail. I brought them the vavle guides which they didnt install. I put the head on, car started but barley fires cyl 2. After compression and leakdown tests with nothing showing i pulled the head. I noticed oil in the exhaust port of cyl2 form a bad seal. Dropped the head off at a repudable machine shop monday. Today, wed. they get back to me saying the valve guides are warn and an intake valve is slightly warn. So now the head is getting that valve replaced, all the seals replaced, and the exhaust vavle guides replaced. Should be done monday, well see :D
    Thats all for now folks
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    ma head is hurr :D, shop found another fucked up intake valve from a incorrectly installed seal or something. so they replaced that valve with out uppin the price. Shes all clean and decked. im gonna go install her :D :D :D
    so i had:
    intake valves replaced: x2
    all seals replaced
    all exhaust guides replaced
    decked
    cleaned
    plus the supertech exhaust valves chillin in there from the first work i had done on the motor means this baby is ready to purr
    Feb 27 2005
    North Wales, PA
    cost on that head work?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    HURRY UP!!!!!!!
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Apr 14 2008
    a4 avant
    marlboro
    nice build love seein all these bad boy builds...starting my thread again in a day or so
    -vrt-
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Quote Originally Posted by Poopie View Post
    500 bucks :(
    Sep 14 2006
    Lansing, MI
    damn, that much. i got mine done for $200
    SOLD
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by pipe7284 View Post
    What work was done to your head exactly?
    $500 sounds about right for a proper job.
    Apr 14 2008
    a4 avant
    marlboro
    mines costing 500...shop fuckd up tho and quoted me 1400 to do my work...eating 300 yay
    -vrt-
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Yeah i feel 500 is about the average price. They pulled everything and checked everything. replaced all the seals, exhaust valve guides, replaced 2 intake valves that were messed up, decked the head, cleaned it up, and leak tested. Ive seen people pay more for less. i think they did something to the intake valves too but i forget what. even though we have 5valves im glad we only have one head lol. Id cry if i messed up a 03-04 cobra top end. 2 heads 4valves
    Jan 25 2006
    A4 2.0T
    MD
    Did you get a 3 angle valve job?
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    no, did not... didnt even think of it. probably should have, but o well
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Cost me $350 to have the valve seats cut and new valve seals put in along with reinstalling the valves and springs (new springs and exhaust valves I supplied). $300 for the labor and $50 for the seals (got shafted on the seals since they are like $1/piece from ECS Tuning)
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by A4 TSCHUSS View Post
    What about valve guides and a valve job?
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by t1demont1 View Post
    Sean, how familiar does this look?
    - Clint
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Sounds about right. Glad to hear its done correctly and all the necessary checks and balances were covered.
    Imagine having to do two of these heads? That's what the B5 S4 guys are doing.
    David. I hope you got valve guides installed or at least had them measured for wear.
    -Doug
    Jan 25 2006
    A4 2.0T
    MD
    I thought of you when I saw that picture.
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    what fuckin good is anybody anymore? This damn head still isnt fuckin fixed! wtf?! before i threw the head on, I put the head on its side and spun the cams to check everything out. I noticed on cyl2, the cyl I had problems with, an intake valve looked like it wasnt shut all the way when it was supposed to be. So i took a flashlight and shined it into the intake ports sure enough all was dark when closed except for this one fucking valve on cyl 2. Im so pissed, so im going to the machine shop tomorrow after school. wooo fckin hooo more downtime because this head was failed to be fixed twice now. Im guessing its a valve seat, but why the hell wouldnt they check that
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    now i feel fuckin crazy because i went back out into the garage to look at it again and its not doing it anymore?! wtf would cause this? I dont wanna put the head on the car becasue i know somethings not right, but im gonna have a hard time explaining this phenomenon to anyone. i wish i snapped a pick of the light getting through.
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    How am supposed to explain this to a machine shop and tell them to fix something that doesnt look wrong but i know is.
    Jan 25 2006
    A4 2.0T
    MD
    Did they pressure test the head?
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Ill ask them when i call them tomorrow morning I dont think they did, i think all they did was pour oil into the intake and exhaust ports to see if they leaked out the valves at all since there was some fresh oil on the head when i picked it up. Im not sure if pressure testing would show anything since this didnt even show up on my compression tests and leak down.
    I just know what i saw was what caused my cyl2 not to fire when the head was on. I have a feeling if i saw it open then, it wont seat properly when the cars running and the cams are opening and closing thousands of times a minute
    Feb 27 2005
    North Wales, PA
    I don't think its the seat. Double check the lifter and the springs.
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    I thought it might be the seat because it looked seated on one half, but the other half was open. Im 99% sure its not the lifter becasue the cam never even hit the lifter once when i noticed the valve was open
    Feb 27 2005
    North Wales, PA
    did that valve get replaced? hhmmm sounds like a crooked guide maybe.
    Sep 14 2006
    Lansing, MI
    wow Brended, this sucks. that head has cost you alot more than the BT build...lol
    SOLD
    Feb 27 2005
    North Wales, PA
    my head will end up being the most expensive part of my build. when all said and done i've probably sunk about 2gs in my head and its not even ported.
    used aeb head with a ton of bent valves - $150
    clean and 3 angle valve - $200
    replaced a few lifters - $70
    revolver cams - $600
    new valves - $500
    cam chain tensioner - $140
    034 valve springs $250
    uugghhh so sad and i still need to buy new guides and have them installed...which will be like $250
    Oct 29 2005
    10speed
    San Francisco, CA
    new valves - $500
    Tell me about it man...
    Used AEB head - $150
    Supertech Exhaust Valves
    Cat Gold Valvesprings
    Ti Retainers
    Cat 3652 Cams
    Cat cam gear
    probably ~$2100
    - Clint
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    yeah taht valve was replaced. all the vavles were put on a machine and tested for straightness. I was told all the intake guides were good and that exhaust guides wear out way before intake guides. maybe its the spring... it looks like it gets really close to the head, so maybe it could grab the head on compression and not release right away? defect in the head or something?
    i want this shit figured out god damn i just wanna drive this beast. at this time i wish i would have spent the extra cash and gotten vavle springs and titanium retainers and had them put in so i could throw in cams later.
