I know its a B6 but there's a lot of good info in these links to help out a few of you B5 guys
History:
So, my car started as a pseudo bone stock 125,000mile 2002 A4 1.8T Avant. December 2007 I took AutoSpeed Performance up on their offer for their GT28RS turbo kit. Also installed a Southbend OFE SS clutch with my OEM DMFW while we were at it. My APR Stealth cat-back exhaust was also put back on with the GT28RS kit.
January, continuation of tuning and the car was not behaving. We left the tuning as-is. Dyno numbers were in the 275awhp range on 93octane. I also stumbled upon an AMU longblock for a good price so I picked that up (just to have).
February. I go out to Colorado to take advantage of their amazing winter. Nothing but powder runs for a week straight
Next on my list was eventually to be a fully built motor and some stuff. Timeframe was about a year or two later. Given my tune was not optimal I moved this phase of my car up in schedule. Enter my AMU motor. I stripped it and kept just the block and cylinder head. Comissioned Bob Quindazzi of QED Power to build me up a proper 2.0L stroker with my AMU block and head. This build was going to be done correct and with a plan from the get-go.
AMU motor was stripped in March. Block was dropped off at QED's in April. Engine was built and swapped into my Avant in June. Turn Key on the new motor was early July. 5,000+ miles later (early September) the AVant is back at ASP for tuning.
Engine:
2.0L stroker motor
- AMU (06A casting) block and cylinder head
- AEG 92.8mm stroke crank
- Supertech 82.5mm bore forged pistons
- Scat forged connecting rods
- OEM main bearings
- OEM oil pump
- OEM timing belt kit w/ metal impeller water pump
- Supertech Inconel Exhaust valves
- Supertech valve guides
- OEM intake valves
- OEM hydraulic lifters
- Cat Cams 3651 camshafts
- Cat Cams adjustable cam gear
- basic valve seat grind/lap
Forced induction:
- Garrett GT2871R turbocharger
- ASP GT28RS hardware kit with manifold and downpipe ceramic coated
- ASP FMIC
Tuning:
- Custom Me7 tune by ASP (currently in process)
Other stuff while the Avant was down:
-2.8L 5spd manual trans
-4:1 center diff
-034 MotorSport Street Density motor & transmission mounts
-JHM 'solid' shifter & shifter linkage & bushings
-custom boost gauge in rear view mirror
-custom ash tray mount for EBC
-RS4 rear anti-roll bar
-034 MotorSport B6 High-Output Fuel Pump
-drive-way motor swap
Links:
Original build thread: http://audizine.com/forum/showthread.php?t=198330
4:1 center diff mod: http://audizine.com/forum/showthread...78#post2646778
First turn-key start on 2.0L motor: http://audizine.com/forum/showthread.php?t=223107
Cat Cams 3651 install thread (couple thousand miles into new motor): http://audizine.com/forum/showthread.php?t=229219
boost gauge in rear-view mirror: http://audizine.com/forum/showthread.php?t=234102
034 high-output fuel pump install (5,000miles into new motor): http://audizine.com/forum/showthread.php?t=233462
EBC install in ash tray: http://audizine.com/forum/showthread.php?t=217996
The Avant:
all my photos:
http://flickr.com/photos/omega29/set...7604479782061/
Once I get my car back (fully tuned) from ASP I am going to fab up a heatshield for my intake. I will also take apart my 1.8L 5spd transmission this winter. Most likely rebuild it with new syncros and swap in a European TDI 5th gear for highway cruising. Then put the trans back in the car and sell the 2.8L trans.
