After doing an oil change on my new car and switching from Dino oil to synthetic I noticed a pretty good oil leak. The drain plug and oil filter were on so hard that I thought that it was the crush washer on the drain plug at first but upon further inspection it appears the oil is coming from right above the oil filter. I didn't notice any oil on the starter so I am assuming that it is the oil cooler seal and the reason it is leaking more than before the oil change is because the synthetic is thinner when hot.
My question is this: I read the DIY for the 1.8t and it says that the 27mm nut should be hand tightened, is this true? Also does anyone know if I can get the cooler off without taking the coolant lines off? I don't have any G12, I don't know where to get any besides the dealer, and I would rather not be at the dealer for the third time in three days since it is a 40 minute drive each way.
Thanks guys
