Results 1 to 9 of 9
    Sep 23 2008
    Audi, F150, Expedition
    GA
    Noob needs softer supension recommendations...
    Noob here, recent Audi convert: 2001 A4 B5, 1.8T fwd, revo chip, MTM DV. I'm looking to upgrade my suspension but primarily interested in "softer" options, if the Mrs. says it's too rough a ride, my mods are over. I would like recommendations on suspensions more geared toward comfort than track...stiffer than stock but not much more so while lowering 1.5+". Any recommendations would be greatly appreciated, not much help on other boards since I'm not asking for track setups. This is a daily driver looking for the next step up without sacrificing the current comfort. Thanks for your help...
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Noob needs softer supension recommendations...
    Konis with aftermarket sport springs.
    Jim
    I Do Werk.
    Dec 05 2007
    The only springs I know of that are sport (which is what you would want for a softer ride) which gives you 1.5" drop is the Nuespeed Sports. You will not get the + unless you go race springs or coilovers (I do not know how soft you can adjust the dampening with ones such as Koni/Stasis).
    Koni Shocks and Nuespeed Sport Springs
    Established Member Two Rings oneighty's Avatar
    Aug 30 2007
    i have the eibach prokit over stock sport dampers on my car and it feels nice
    -Jonathan
    '00 A4 1.8T K&N | InMotion Tuning | Forge004 | AutoMeter boost gauge | Eibach ProKit | ST sports | Avus S4 | 6000K HIDs
    Dec 05 2007
    ^What is the drop like? Do you have any pics you can post ot PM me? Thanks!
    Feb 27 2005
    North Wales, PA
    konis with sport springs like jim said or vmaxx coils.
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    H&R Sport springs + KONI Sport shocks. Ran them for years on my B5A4FWD and they were very comfortable.
    Mar 09 2004
    nw michigan.
    Koni is definitely the way to go for the dampers. I've just driven two very similar setups and the one that should have been stiffer was on Konis and rode better. One was my daily driver A4 Avant with Shine 400 pound springs and Bilstein HDs with just a rear H-Sport bar, nothing up front. The other was my old company car S4 Avant with 500 pound Shine springs and Konis and both H-Sport bars. So the S4 is 10% heavier but has a 25% higher spring rate so it should be stiffer. My car is more comfy with the big front bar on the shelf so the S4 should be choppier over bumps. It makes my car feel like a clunker. The S4 is just smoother. It is the one for the ladies and still just as good on the track.
    Jim
    I Do Werk.
    Sep 23 2008
    GA
    Thanks for all the responses guys. Looks like Koni is the consensus for shocks. I'm leaning toward the H&R sports as they have been mentioned numerous times on other boards too. Don't think I really need coilovers, they are a good bit more expensive and I would think more tricky setting up (balancing) to get any advantage over a spring/shock package. I can do without the additional drop, a 1/4-1/2" won't make any difference to me. Thanks again for the input, you've helped narrow down the decision.
    Mike@PureMS, you got mail.
    JC
