Results 1 to 10 of 10
    Registered Member Two Rings tdubz's Avatar
    Aug 16 2007
    Revo Stage 2 Boost Problems
    im having a peoblem I just got my car chipped to Revo Stage 2 and the car is running fine no codes or anything but it wont boost past 15psi and I cant seem to figure out whats wrong, the tech hooked it up to the computer and it says its requesting 21psi but it still wont go past 15
    2003 Audi A4 1.8T l Revo stg2 l Boosted Tech CAI l RS4 Sway Bar l Podi Boost Gauge l 20% Tints l VMR Test Pipe l Magnaflow 14851's
    Veteran Member Three Rings oregonaudi's Avatar
    Oct 06 2006
    Re: Revo Stage 2 Boost Problems
    Boost leak test.
    So when he hooked it up to the computer, you mean he did a log while driving, right?
    'Cause if that's the case visit www.a4mods.com and look for the boost leak test write-up to find a fix
    Modded 2003 1.8TQM - GONE
    NOW - 2007 Ibis S-Line Avant 6MT
    RAI KOR-GT ** S3 Injectors ** 034 TIP/Custom CAI ** Uni Tune ** APR HPFP ** Racetech FMIC ** 034 HFC W/ Labree Downpipe and Custom Exhaust ** BSH Stage 2 PCV Fix ** Southbend Stage 3 Daily ** DTM 25th S4 Front W/ DTM CF Splitter ** Painted Vorsteiner Hood ** iForged DTMs W/White Lips
    Aug 16 2007
    it's around 20 in vaccum though so would there still be a boost leak?
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    what diverter valve do you have?
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Aug 16 2007
    the audi tt one
    Oct 06 2006
    yeah, there can still be a leak, but it could be small and take 15lbs of pressure to show up
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    might be your N75.
    if it goes down to 10 or 11 psi and can't boost past it, but you don't hear any hissing leaks then i'm definitely saying N75 valve.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Aug 16 2007
    yea I dont hear any leaks or anything it's weird some days the car feels sluggish and then some days it feels like it wants to go, so u think it could be the n75?
    Feb 07 2006
    ouellette
    I had the same problem and the vacuum line leading to the DV had come unplugged.
    Aug 16 2007
    ok im gonna check it out, thats the hose that comes off the top of the dv right?
