So I have been getting rough road cel's for the past month. I had the abs module replaced today and we are having some problems. when we started the car the abs light was on ran it on vag and it said that the right front speed sensor has an open circut. I check, its plugged in, pulled it out cleaned it off and cleared the codes. When we start it up same problem the code is still there. Now I may be wrong but wouldn't you have to drive the car to get that code, it hasn't moved at all. Also I never had the code before. We even put the old abs module back in with no code appearing.
