Results 1 to 9 of 9
    Aug 05 2008
    Petaluma, CA
    What is behind the fog light knockout?
    I noticed a lot of you guys with the 2.0 don't have that knock out that sits to the inside of the fog lights. I read some where that the bumper incorporates some brake cooling, is that where it comes from? In some photos I have seen it almost looks like there is some channeling behind the knockout, almost like a scoop. I have a 2006 non sline 3.2. I have searched but only come up with installing rs4 fog light grills and what not.
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: What is behind the fog light knockout?
    Are you talking about the rubber piece? it channels the air into the SMIC's on both sides. some people might not have them because they have a FMIC!
    The usual things!!
    Resistor Install
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    I think it directs air to the SMIC.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    DUH! an Audi
    los angeles, CA
    if you are talking about those black pieces next to foglight, like others it purpose is to direct or funnal air to the smic.
    3.2 do not have this because they are not turbo'd.
    I have not heard about that brake cooling you are speaking of, any links?
    Aug 05 2008
    Petaluma, CA
    http://www.internetautoguide.com/rev...alkaround.html
    Middle of the page. Yes I know I don't have a turbo nor IC.
    DUH! an Audi
    los angeles, CA
    Laterally split intakes below the body-colored bumper and outboard of the grille do dual duty, housing fog lamps and channeling air toward the front disc brakes.
    from that reading, if thats the sentence, to me it sounds like its sending air towards the front brakes...but not specifically at them. It could just be the way I am trained to read =x
    but would be nice to know if the brakes do in fact get air
    Aug 05 2008
    Petaluma, CA
    http://www.automobilemag.com/am/2006...fications.html
    That even list the front brakes as being ventilated discs....
    Sep 15 2005
    Norwalk, CA
    Quote Originally Posted by darge13 View Post
    i think you are mistaken about what a ventilated disc is.
    http://www.giant.net.au/users/wight/...comparison.jpg
    the top one is a solid disc (you will likely find those on the rear axle of modern cars), and the bottom one is a ventilated disc (most modern passenger cars use that on the front axle)
    Peter
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    its for the smic's..
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
