Results 1 to 7 of 7
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    Transmission Related - Plug on bellhousing?
    When I installed my egts some time ago I noticed that on the drives dide of the bell housing (it seems to be on the bellhousing) there was a hole in the transmission.. kinda looks like a plug of some sort goes there.. here is a pic.. look behind the egt to see the hole:
    Now, does a plug go there or is that some kind of a vent? also, is that hole on the bellhousing or is it on the transmission itself(the part that holds oil).. I ask because if it is on the transmission I may have to dump the oil and put new oil in since there is the risk that water got in there...
    Please, no guesses, only reply if you know for sure.
    Thanks,
    Jonathan
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Feb 17 2008
    Ottawa Ont.
    Re: Transmission Related - Plug on bellhousing?
    no its the dry area around the clutch, my car has nothing there either and i wondered the same.
    its normal.
    PS you need a new o-ring for your green coolant temp sensor. :)
    Feb 22 2007
    Earth
    how can you tell the O-ring is bad from that picture?
    Quote Originally Posted by BastardS4 View Post
    its normal.
    Feb 17 2008
    Ottawa Ont.
    the crud around the retention clip.
    Feb 22 2007
    Earth
    wait.. I thought the temperature sensor was on the passenger side.. this is the driver side.. I'm confused...
    Veteran Member Three Rings 2kblacks4's Avatar
    Jan 04 2007
    2000 black s4 6spd
    Birmingham Al
    Driver side is the after run coolant sensor and the temperature sensor is on the passenger side. He is right it wouldn't be a bad idea to replace the o-ring. you can pick them up the deal for under a buck. Also get a extra clip or two just in case you break one which happened to me, they are really cheap as well.
    4:11 posi track out back, 750 double pumper, edelbrock intakes, bored over 30, 11 to 1 pop up pistons, turbo jet 390 horse power, where talking some fucking muscle!!
    Feb 22 2007
    Earth
    Will do.. thanks for the replies
    Quote Originally Posted by 2kblacks4 View Post
