Results 1 to 6 of 6
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Transmission & Differential Oil
    How often do you guys change your transmission and differential oil? I'm at almost 21k and I havent done either. Just wondering
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Re: Transmission & Differential Oil
    I believe our tip transmission does not require oil change, nevertheless I will be changing mine either 6 months or 10000KM before my warranty expires.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Jul 21 2004
    South Florida
    I'd probably do "lifetime" fluids every 40K or so along with the diffs. You could probably go with 60K mile changes if not as conservative of intervals are comfortable for you. Most BMW techs/afternarkets that i've seen stick with those recommendations on their lifetime fluids.
    cheers! Mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings SilverB7FL's Avatar
    Feb 19 2007
    Built Twin Turbo 350Z
    S. Orlando
    I think in the service manual that came w/ the car it gets done around 40k. I'm getting close to that sadly.
    Girls love Audi too.
    Senior Member Two Rings D-techniK's Avatar
    Feb 24 2008
    Miami Lakes, FL
    Did mine at 40k. (at Novitech tuning they charged me less than 1/2 of what the dealer quoted me)
    http://www.novitechtuning.com
    Sep 02 2008
    Boston, MA, USA
    Is the front diff part of the trans (and therefore shares fluid)? Do the trans and the rear diff take the same fluid?
