Results 1 to 9 of 9
    Jul 26 2008
    Jersey
    Want to log my car tonight - what blocks?
    I've got a pretty much OTS AWE kit, I want to tweak it a little - I know there's more...
    What blocks should I log? Thanks!
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: Want to log my car tonight - what blocks?
    Well what kind of information are you looking for?
    Stage 3+ RS6's
    Jul 26 2008
    Jersey
    Quote Originally Posted by deb38 View Post
    Well what is most crucial to log when attempting to make tweaks?
    Basically I want to know how the timing and A/F mixture looks, see if I need to lean it out, fatten it up, add/pull timing, etc..
    Veteran Member Three Rings phantom b6's Avatar
    Apr 02 2008
    LA
    022 should be timing, 031 will be your lambda factor (multiply by 14.7 to get your actual AFR)
    APR 1+ | 380cc Injectors | APR TIP | FMIC | Snow Performance Methanol Injection | ATP 3" Downpipe
    Dec 11 2006
    Boston
    003, 115, 020
    don't log too many at one time.
    Stage 3+ RS6's
    Jul 26 2008
    Jersey
    What is block 020?
    Does anyone have a list??
    Dec 11 2006
    Boston
    Stage 3+ RS6's
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Jul 26 2008
    Jersey
    I'm getting throttle cut..
    Tuesday 23 September 2008 19:52:34
    8D0 907 551 M 2.7l V6/5VT G 0002
    Group A: '003 Group B: '020 Group C: '115
    Engine speed Mass air flow Throttle angle Ign timing Cyl 1 Cyl 2 Cyl 3 Cyl 4 Engine speed Engine load Spec'd Boost Actual Boost
    TIME g/s 0-5deg=closed deg TIME TIME 990-1800 mbar <=1800 mbar
    MARKER STAMP /min g/s % °BTDC STAMP CF CF CF CF STAMP /min % mbar mbar
    1.36 3560 189.39 93.3 5.3 0.54 0 0 0 0 0.94 3360 139.8 2380 2160
    2.78 4360 189.92 45.5 2.3 1.87 5.3 3 6.8 5.3 2.37 4160 155.6 2330 2450
    4.06 5040 212.83 48.2 3.8 3.2 4.5 2.3 6.8 4.5 3.63 4840 147.4 2320 2370
    5.47 5760 258.03 100 3.8 4.53 3.8 1.5 6 3.8 4.97 5520 151.9 2390 2340
    6.93 6440 280.72 100 7.5 5.93 3.8 1.5 5.3 3.8 6.43 6200 155.6 2540 2490
    8.37 5040 13.14 7.8 8.3 7.42 3.8 4.5 5.3 3 7.92 5240 9 1020 1310
    9.69 4840 15.36 8.6 7.5 8.81 0 0 0 0 9.25 4920 10.5 1020 1110
    10.99 4600 14.64 8.2 6.8 10.13 0 0 0 0 10.56 4680 10.5 1020 1100
    12.37 4280 13.86 8.2 6 11.42 0 0 0 0 11.85 4400 10.5 1020 1090
    13.69 4000 12.94 7.8 5.3 12.77 0 0 0 0 13.28 4120 10.5 1020 1090
    14.99 3680 12.19 7.5 4.5 14.21 0 0 0 0 14.61 3800 10.5 1020 1080
    16.3 3360 11.19 7.1 2.3 15.41 0 0 0 0 15.9 3480 11.3 1020 1080
    17.52 3040 10.61 6.7 2.3 16.7 0 0 0 0 17.1 3160 11.3 1020 1070
    18.72 2600 8.86 6.3 4.5 17.92 0 0 0 0 18.32 2760 11.3 1020 1070
