    Apr 18 2007
    ny
    Question Propshaft rear seal problem on my 03' 2.7t...........
    This is the 3rd propshaft rear seal that they changed. The first one was about a year ago, then a few weeks ago I got some oil drippings in my garage, they told me it was the seal so they changed it. Yesturday I look in my garage and I saw the same drippings in the same spot, when I brought my car to Audi today they said it was a faulty seal, is that possible???? Can there be anything else causing the seal to break or wear prematurly??
    Feb 17 2004
    Sterling, VA
    Re: Propshaft rear seal problem on my 03' 2.7t...........
    Quote Originally Posted by A62TURBO View Post
    Is this the one at the tranny or the one on the rear diff? Is your tranny a manual or a tip.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Apr 18 2007
    ny
    It's the one at the tranny and my car is tip.
    Sep 04 2007
    04 Allroad 4.2, 1996 BMW 328is
    Philadelphia, PA
    Excessive clearance in the propshaft bearing/bushing will cause the shaft to wobble & damage the seal. If the surface that the seal rides on is damaged, same thing.
    Apr 18 2007
    ny
    Well if I get another leak I'm gonna be pissed.
