Results 1 to 32 of 32
    Veteran Member Three Rings 3 bar's Avatar
    16 SQ5, 14 A7 Tdi, 91 Corrado, 02 Passat wagon, 99.5 A4 TQM
    Greensboro NC
    When starting my S4 doesnt turn over for about 30s to 3min when cold WTF is going on?
    When I try to crank it nothing happens for about 30 secs to over 3 min then out of the blue it turns over. Anybody else had this problem? is it a sensor?
    2004 Atlas Grey A4 Avant
    1999.5 Volcano Black Audi A4 1.8TQM
    2002 VW Passat wagon 1.8t 5 speed
    1991 VW Corrado 1.8t w/matching trailer Waterfest 03/04 winner (show)
    1980 Chrysler Cordoba LS 371ci 450hp 12.68(go)
    Jul 21 2004
    South Florida
    Re: When starting my S4 doesnt turn over for about 30s to 3min when cold WTF is going
    Starter. It will get progressively worse in the cold especially. Good luck getting audi to replace it. I had them replace 3 or 4 different things all the while telling them to fix the starter. IT went on for literally over one full calendar year with my car in the shop for over a month in all. Cost me hundreds in rental car as well. Theyll try replacing the ignition (50 dollar part), or "cleaning the contacts" (another term for blowing you off), or replacing relays. It's usually the starter. If you search on audiworld, you'll see over a dozen individual accounts of the same thing.
    cheers! Mike
    2018 Audi S5
    Gone-
    Veteran Member Three Rings ChronicTeutonic's Avatar
    Apr 11 2008
    1978 MGB, 2006 Vespa LX-150
    Pasadena, CA
    Could be the clutch safety switch?
    2005 Brilliant Black B6 S4 Avant - K&N Drop-In, Thermal R&D cat-back, VAGed, Höen Xenonmatch Fogs
    2009 United Grey MKV GTI - 18 in. Hufs, APR Stage 1
    ChronicTeutonic's Past Teutonics:
    BMW 2002 (x2), VW Microbus, BMW 320i, VW Corrado G60, VW Jetta IV
    The Avant Garde
    Jan 24 2008
    West Coast
    Quote Originally Posted by bhvrdr View Post
    cheers! Mike
    I would have taken it to an indy mechanic and TELL them what to replace if that was the case!
    Moderator
    Jul 21 2004
    South Florida
    You ought to see what Audi charges for a starter replacement. It was about a grand. If I had replaced it out of pocket I would have never been reimbursed. I've done that before and Audi never gave me my money back. Did it on a failed MAF.
    I even had videos of my problem over the course of the year with date stamps and everything. If you search my screen name here on youtube and the word "cold start" they should come up. I think there's 10 videos, he.
    cheers! Mike
    2018 Audi S5
    Gone-
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Mine had the exact symptoms and turned out to be the starter too. There have been several post's here and on AW on this subject.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Mar 02 2008
    Cleveland
    Check the clutch switch first with an ohm meter, cheap fix.
    Greensboro NC
    Well I took it out and brought it to the local starter repair place. Got a call back stating that in fact the solenoid was shot but they could not find any repair parts for it.
    Where did you guys get your starters?
    Apr 11 2008
    Pasadena, CA
    http://www.genuineaudiparts.com/ has a starter listed for about $450
    The Avant Garde
    Greensboro NC
    Thats more expensive than the dealer!
    Jul 21 2004
    South Florida
    http://www.genuinevwaudiparts.com
    they have it for $281.52
    2018 Audi S5
    Gone-
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    maybe battery?
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Does anyone have a DIY on replacing the starter?
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Apr 11 2008
    Pasadena, CA
    None that I know of, but I reviewed the Bentley manual and you'll need to support the engine since the right side engine mount needs to come off to access the starter.
    The Avant Garde
    Greensboro NC
    Not true. I got mine out without taking the engine mount loose.
    Apr 11 2008
    Pasadena, CA
    Sorry just reporting what is in the Bentley manual, YMMV, I've never done it. Maybe they add the extra steps in there to maximize billable labor hours?
    The Avant Garde
    May 30 2007
    MA
    Quote Originally Posted by 3 bar View Post
    Care to explain your process?
    2014 R8 V10 - Gated
    Greensboro NC
    I removed the electrical connector and both the bolts and tilted and twisted the starter between the mount and subframe and it just came out.
    May 30 2007
    MA
    Quote Originally Posted by ChronicTeutonic View Post
    Can you please post this bentley diagram or send it to me? I need to know how to do this as my starter I is shot. Is the general consensus that none of the electrical switches fixed the problem?
    2014 R8 V10 - Gated
    May 30 2007
    MA
    anyone with a bentley??
    2014 R8 V10 - Gated
    Apr 11 2008
    Pasadena, CA
    In order of the images:
    1) Remove the plastic cover
    2) Attach a shackle to the lifting eye
    3) Install support over engine compartment, attach shackle to threaded lifer, and use the lifter to release the tension on the engine mounts.
    Now that is the factory way, but I'd just follow steps 1 and 2 then rent a cherry picker and hook it to the shackle to release the tension on the engine mounts. If you're a good welder I'm sure you could make up a tool like the one shown in the image. BTW that engine support is a pretty standard item in the VW/Audi world, I recall seeing a similar item in the service manual for my old Jetta IV.
    Now I'll paraphrase the rest just to avoid any copyright issues...
    4) Remove the right wheel. Drop the belly pan
    5) Unbolt the four nuts retaining the anti-roll bar (no need to remove the bar just unbolt it so you can get to the rest of the stuff)
    6) Remove the nut that attaches the wiring harness to the mount bracket.
    7) Remove the nut that attaches the engine mount to the support bracket. The remove the bracket itself by undoing three bolts that attach it to the frame.
    8) Remove the clip holding the A/C refrigerant line.
    9) Disconnect the electrical engine mount harness (must be to monitor for wear?) Unbolt the mount from the engine block.
    10) Remove the front axle heat shield
    11) Disconnect all connections from the starter and unbolt it from the bellhousing.
    Reinstall is reverse here are the torque values (IMPORTANT):
    Starter to trans - 65nm
    B+ Terminal to starter - 16nm
    Ground strap to starter - 22nm
    Engine support to block - 42nm (use locktite)
    Drive shaft heat shield - 23nm
    The Avant Garde
    May 30 2007
    MA
    Great thanks!
    2014 R8 V10 - Gated
    May 30 2007
    MA
    Ok so the problem here appears to be the solenoid. Which makes sense because if it were the starter and the solenoid was good, the starter would still click. Now, genuineaudiparts does sell just the solenoid so I am wondering if I should just get the solenoid or the who starter...
    2014 R8 V10 - Gated
    Apr 11 2008
    Pasadena, CA
    Bump... I added the rest of the steps and torque values...
    The Avant Garde
    Apr 11 2008
    Pasadena, CA
    SuperAvant, are you going to do this? Would you mind taking pics and collaborating on a DIY?
    The Avant Garde
    May 30 2007
    MA
    Certainly - I am going to do it this weekend. I am going to see if I can get it done without removing the engine mount...
    2014 R8 V10 - Gated
    Apr 11 2008
    Pasadena, CA
    I'm guessing all this removal of bits just makes it "easier" to extract the thing... maybe the Audi mechs aren't allowed to cuss on the job so they have remove the engine mount in order to keep swearing to a minimum?
    The Avant Garde
    Greensboro NC
    I didnt have to do any of this I just unplugged the cables and removed the bolts to the starter. A little knudge when the starter housing was in the mount bracket and it came out and in. I got a rebuilt starter from partstrain for $117 + 100 dollar core charge.
    Apr 14 2004
    rs4, ruf, rs7
    L.A./Vancouver
    I have the same problem...from time to time. Funny thing is when i use my other key, my car starts every single time without any issues.
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    3 bar
    After you replaced the solenoid. did they tell you what or why the solenoid failed? Did they find something that would be a issue that might come back later in the solenoid?
    Greensboro NC
    Quote Originally Posted by Justincredible View Post
    3 bar
    I replaced the starter and the solenoid. for $117.00! They told me the solenoid was shot but the rest of the components were worn as well. They only told me it was shot. They didnt give me an explination as to any weak link within the solenoid.
    Veteran Member Three Rings AndreNY's Avatar
    Apr 06 2005
    Boston MA
    well im joining the crw im having the same issues, so im assuming the Starter SOlenoid is the major cause for the car not starting?
