Results 1 to 14 of 14
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    How do you remove the radio?
    I bought some keys from Wally World and stuck it in the slots (curved side facing in towards the radio). When I pull on the keys, they simply come out without the radio moving. Could it be that the keys were junk? I bought a set of the official ones and waiting for those to come in and try again. Any ideas?
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: How do you remove the radio?
    I have 4 of these - I use the longest one. The notches face into the radio - it will click into place.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by kwimberly View Post
    Do you have to pull all 4 simultaneously? If so, how do you guys do that? It is fairly tough for me to get my hands on all four keys and yank at once with equal pressure to all 4 keys.
    USP Member 110
    May 03 2008
    Orlando
    I have four arms.
    No - once you put each key in properly, the latches will be released. Then, you can simply pull on the top keys, the bottom keys or any other place. The keys just depress the spring loaded latches at each corner.
    Kevin W.
    Jun 15 2008
    Fairfield, CA
    I have four arms.
    See, Tried that that the keys I bought from Wally World to no avail. I hope the "official" ones will work better.
    USP Member 110
    May 03 2008
    Orlando
    you should hear a click when the key is inserted all the way.
    It sounds like your keys aren't long enough - they are sliding in and not catching anything, thus they slide right back out.
    Kevin W.
    Jun 15 2008
    Fairfield, CA
    Yes, it would click and then when I pulled it would have a little resistance...pulled a little harder and out it goes!
    USP Member 110
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    They are a pain in the ass, be careful not to cut yourself when pulling on the keys.
    GO KNIGHTS!
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by sloweryucf View Post
    I noticed that too, these things can sliced your fingers up pretty badly if you are not paying attention.
    USP Member 110
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    lol i have those keys too buy i used cut up old credit card i did right side then left side pulling by cassete hole.
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    if you can't pull the radio out by pulling on the keys, then removing the glove box will allow you access to the to back of the head unit and you'll be able to push it out.
    MY2022 B9 Q5 55 TFSIe: Daytona Gray||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Jun 15 2008
    Fairfield, CA
    Quote Originally Posted by BOPOH View Post
    Tried that too, did not move at all!
    USP Member 110
    May 03 2008
    Orlando
    maybe you're just a weak sissy?
    Kidding. If you were local I would drive a set over - I have several.
    You're getting 4 clicks and some of them are still sliding back out?
    Kevin W.
    Registered Member Two Rings zims666's Avatar
    Apr 17 2008
    '05 A4 B6 1.8t 6speed
    Chapel Hill, NC
    aww the 1st mod i ever did
    this was a bitch for me too, till i realized that the notches on the keys need to face 'in' towards the radio.
    use these: http://enfigcarstereo.com/shopsite_s...ND_42_002.html
    when each one is pushed all the way in, they will click to engage.
    and trust me, they are locked in there till the damn radio comes out. i needed two screwdrivers to hold the tabs down while pulling the keys back out.
    by pulling towards your windows on the keys, then out towards you, it should come out with some wiggling. use the tape player if you have to. thing weighs a ton so it might take some force to budge it...
