Results 1 to 14 of 14
    Veteran Member Three Rings rAphb0y's Avatar
    Jun 21 2008
    Boston
    My Car Starts But Dies Right Away Won't Let Me Give It A Little Gas Or Anything
    Its A 2.8 Fwd .. Does Any1 Have Any Idea Why This Is Happnening?
    Some1 Help Me!!!!
    Senior Member Three Rings outkasta4's Avatar
    Dec 26 2004
    96 A4 2.8, 02 A4 1.8t
    central coast,CA.
    Re: My Car Starts But Dies Right Away Won't Let Me Give It A Little Gas Or Anything
    maybe your key became unprogramed and you need to reprogram it, I know from past experiences this seems like your problem hope this helps
    Jun 21 2008
    Boston
    go to an audi dealer and reprogram the key?
    Sep 17 2006
    07 cbr600
    Y Do Poeple Type Sentancas Lyke This. Every 1st Letter Capitel N Shyt. Its Evin Anonying To Type Lyke tis.
    Sorry, I'm no help.
    Registered Member Two Rings
    Jul 24 2008
    Los Angeles, CA
    Your intake hose may be loose. Double check all of your hoses under your hood.
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    first thing that comes to mind is a faulty MAF (i had exact same thing on my old Maxima), then check the intake hose as xqwizit suggested. If that doesn't work try to listen whether the fuel pump turns on - should be a little whine noise coming from the back
    Mar 03 2004
    2014 Allroad, 98 A4 2.8, 00 S4, 03 3.0L A4
    Chelsea, MI
    The symptoms sound like a fuel filter problem. Do you know when it was last checked?
    Veteran Member Three Rings prodrive's Avatar
    Feb 24 2006
    1999 Audi A4 1.8TQ
    Istanbul,Turkey
    Check your fuel pressure if you have a gauge. If it's not the imobiliser ,I looks like you only get the prefueling and than the pump cuts the fuel. You should Vag check your ECU. It may be a fuse or relay or filter I am not sure. Next time type letters properly if you want any help :)
    Just A4 ... A4 which we know
    2.0L - HTA35 - Cat3658 -Autronic EMS - Autronic 500R CDI etc..
    Feedback: Clicky
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    ^ what he said :)
    Jun 21 2008
    Boston
    whats VAG COM ?
    Jun 21 2008
    Boston
    thanks for everybodys help but it came to find out it was the ECU that was messed up .. how? i have no idea cause i hear those are a little hard to mess up ..
    but now car is a little shaky? could it be a vaccum connector? or something else? anyone know?
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    When You Type With The Caps On It Comes Out Like This
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Jul 16 2009
    St. Louis MO
    I have had issues wih the vacuum connector in my old A4...
    Veteran Member Four Rings turbo kraut's Avatar
    Oct 30 2006
    09 pontiac vibe
    StL, Missouri
    wow necro bump....
    2001 Honda CBR929RR - modded - mine
    1992 Ford Bronco - The Beast - mine
    2009 Pontiac Vibe - stock - wifes
    1981 Suzuki GS1100 - sold
    2011 Ninja 650r - sold
    2001 Audi A4 - totaled 3/31/13
    2006 Honda CBR600RR - traded
    1982 Honda GL500 - sold
    2011 Ninja 250r - sold
