Results 1 to 40 of 53
Thread: motor no more
    Apr 14 2008
    a4 avant
    marlboro
    motor no more
    yep this morning started out good dropd a valve into cyl 4 good bye motor....any info on whats needed to make it a 1.9 or a 2.0 058a block
    -vrt-
    Jan 25 2006
    A4 2.0T
    MD
    Re: motor no more
    How high were you revving @ the time?
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Re: motor no more
    check the 20/20 build thread.
    p.s. ouch...
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Dec 05 2007
    Re: motor no more
    That sucks, man. Here is the thread for displacement increase.
    If you need to know of a reputable shop around here, there is one in Central Valley called CIM Motorsports (maybe 1 1/2 mile from Woodbury Commons). He did work on my car before and I recommend him. Unless you know how to . There is also a shop by 5 corners in Vails gate that works on porches and such, but that place seemed too upper class for my liking.
    Feb 27 2005
    North Wales, PA
    Re: motor no more
    i don't know how a guy that works on PORCHES helps...hehe
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: motor no more
    Issam is selling 058 stroker kits: aba crank, supertech pistons, scat rids i think... balanced and machined IM shaft to clear the #4 rod
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Dec 05 2007
    Re: motor no more
    Quote Originally Posted by Poopie View Post
    It's a Euro tuner shop. But most cars I see there are Porches.
    Senior Member Three Rings BaconBait's Avatar
    Feb 17 2006
    In my car with a shotgun
    Re: motor no more
    Poopie is being a smart ass.
    Porches
    VS
    Porsches
    -Craig
    Built: 2.0L Stage 4 3/4%
    Established Member Two Rings Dlay's Avatar
    Apr 22 2007
    2006 A6 4.2 Quattro
    Greensburg, Pennsylvania
    Re: motor no more
    Have them build a nice porch on your A4 so you can have friends over for cook outs.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: motor no more
    ^^^^LOL
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: motor no more
    Read my write up in the FAQ and lemme know if you need parts
    Feb 27 2005
    North Wales, PA
    Re: motor no more
    i'm just busting your balls on your speller error. haha
    Apr 14 2008
    a4 avant
    marlboro
    Re: motor no more
    thanks guys...honestly i was at maybe 3500...and wasnt even beating i guess i beat it too much the prior weak...still dont know exactly why or how it happend but i will definitly chek out those build threads
    -vrt-
    Jan 25 2006
    A4 2.0T
    MD
    Re: motor no more
    Quote Originally Posted by 1fstavant View Post
    How did you confirm that the issue is a dropped valve? Have you pulled the head? Also, was it an exhaust valve?
    Apr 14 2008
    a4 avant
    marlboro
    Re: motor no more
    thats what my shop said...and wen we pulled the plugs mashed to bits...and looking into the block through the spark plug hole...u only see rod
    -vrt-
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: motor no more
    bummer dude. 2.0L BAT FTW, now get to work.
    Oct 27 2007
    In the lab
    Re: motor no more
    Marlboro as in Marlboro MA? I have my shop down in West Warwick RI, I can tow it down there and get it installed in no time... I even have a spare 058 block I can get started with... Which cylinder went?
    Jan 25 2006
    A4 2.0T
    MD
    Re: motor no more
    Quote Originally Posted by 317ssayzarc View Post
    He said #4.
    To OP:
    What was the red line set to on your tune?
    Oct 27 2007
    In the lab
    Re: motor no more
    Quote Originally Posted by Don Supreme View Post
    He said #4.
    sorry, my eyes have failed me
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Re: motor no more
    Sucks, but you had to know it was going to happen sooner than later.
    Jan 25 2006
    A4 2.0T
    MD
    Re: motor no more
    Quote Originally Posted by bassed View Post
    Why do you say that?
    Oct 27 2007
    In the lab
    Re: motor no more
    Well I wouldnt run a sustained 400chp+ motor on stock sodium filled valves...
    Apr 14 2008
    a4 avant
    marlboro
    Re: motor no more
    idt i can afford 2.0 so it mite be a 1.9 bat lol im broke and this car is killing me....anyone buy anything from slowb5 before...is he a good seller, may buy his motor
    -vrt-
    Apr 14 2008
    a4 avant
    marlboro
    Re: motor no more
    nah marlboro ny...and it was set at 7500 unfortunately it was more than likely driver error over failure of parts(hit revy a bunch, missed some gears) how much for the block?
    -vrt-
    Oct 27 2007
    In the lab
    Re: motor no more
    Well Id like to have a look at yours to see if an 83mm bore will cut it, if so we can just do an exchange... Let me know what you want to do, I can take my block to the machine shop tommorrow and start on it... If your getting pistons, a crank is only 200 more, so just 2008cc it instead... I can source the parts too, lemme know
    Jan 25 2006
    A4 2.0T
    MD
    Re: motor no more
    I wish we could confirm it was the exhaust valve that came apart... I am pretty sure it was, but a confirmation would still provide meaningful information.
    I thought some driver error might have been involved - 10,000 RPM anyone?
    Jan 25 2006
    A4 2.0T
    MD
    Re: motor no more
    How much extra labor cost for the machined IM shaft?
    Senior Member Three Rings A4Quattro > all's Avatar
    Sep 23 2008
    Wisconsin
    Re: motor no more
    Quote Originally Posted by maxspeed View Post
    p.s. ouch...
    that'd be my input
    2004 A4 Quattro
    1.8t 6 Speed Manual
    Oct 27 2007
    In the lab
    Re: motor no more
    Think it costed me 40 bucks iirc
    Oct 30 2006
    B8 A4 Avant 6spd
    Re: motor no more
    Someone outta really start making a premade IM shaft.
    -18 718 GTS
    Oct 27 2007
    In the lab
    Re: motor no more
    Issam does
    Apr 14 2008
    a4 avant
    marlboro
    Re: motor no more
    so how much would the whole block run me with parts and labor
    -vrt-
    Oct 27 2007
    In the lab
    Re: motor no more
    Right around 2k, check your pm in a minute -Jake
    Veteran Member Three Rings killa's Avatar
    Sep 23 2006
    500whp A2 vw 16v gti, 97 Audi
    Jersey
    Re: motor no more
    Quote Originally Posted by A4Quattro > all View Post
    that'd be my input
    I went to the same High School as the dude who wrote it and the dude that put down over 500whp out of a stock block 4 cylinder vw
    Bad Ass I Beam rods are finally here. Join the Brute Revolution
    My Car is for sale, click here:http://www.audizine.com/classifieds/...?product=39888
    Apr 14 2008
    a4 avant
    marlboro
    Re: motor no more
    so it was an exhaust valve...but the block is good just needs a rehone...so no 2.0 build gonna throw in new rods and pistons and then put some work into the head
    -vrt-
    Sep 23 2006
    Jersey
    Re: motor no more
    Don't go back and keep the stock rods..
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: motor no more
    Quote Originally Posted by killa View Post
    he had scats already
    - Clint
    Apr 14 2008
    a4 avant
    marlboro
    Re: motor no more
    looks like this so far....
    qed rebuild kit 350 (estimation)
    wiesco 81 or 82 mm pistons 500
    scat rods 400
    this time im doing the head right:
    stock aeb head
    icconel exhaust valves 300
    cat cams (what size you all tell me) 600
    and at the end hopefully a tad bit faster more realiable car, even tho i think the only reason i droped a valve was because of the times i missed when shifting
    -vrt-
    Apr 14 2008
    a4 avant
    marlboro
    Re: motor no more
    any good places to find used heads
    -vrt-
    Oct 27 2007
    In the lab
    Re: motor no more
    talk to johnny, haha
