Results 1 to 4 of 4
    Apr 04 2007
    South San Francisco, CA
    winter wheel and uncommon fender rubbing
    Hi,
    I've several problems and questions about my B7 A4:
    1. I just put my performance wheels back to my car and JUST at the front left side, the wheel is very vulnerable to the fender. It easily scrapes the fender when I pass manholes and slope, however this case doesn't happen to all other wheels. They are just strong!What should I do?
    I also lowered my car..so is this may be the problem?
    2. Since winter is coming, what effect does it have to my performance wheel+tires?Will they flat?I don't plan to use my car to drive on snow, either; but when it's not snowing, I might use it.
    Thanks!!
    Nany
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: winter wheel and uncommon fender rubbing
    Sounds like that corner is out of alignment or otherwise has some suspension damage.
    Apr 04 2007
    So, where should I go to fix it? To the wheel+tire store or suspension fixing store? What do you mean with suspension damage?
    PS: and respond for winter wheel problem,pls =)..
    Jun 14 2005
    Anaheim, CA
    Alignment possibly off in 1 wheel.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
