Results 1 to 14 of 14
    Veteran Member Three Rings Sigma 3's Avatar
    May 23 2005
    Tricities Wa
    Is this a good fuel pump???
    Is any one running this pump? I have a gt 3071r and want o to know if this pump will keep up. I know there are others but the price is right. I will only be running 18-20 lbs of boost since Im on the stock bottom end.
    http://www.atpturbo.com/Merchant2/me...ory_Code=VVWFE
    TIA
    Originally Posted by FNK re getting more power from a 2.8 a4
    "Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Is this a good fuel pump???
    Looks to be a Walbro GSS340 fuel pump, plenty A4 owners have ran walbro pumps in their car by just buying one for $100.
    ATP sells the pump alone for $129
    The metal housing on your link looks like it is designed for the Passat which is different then our A4.
    May 23 2005
    Tricities Wa
    Thanks mike the atp site says its a drop in for the a4
    Jun 01 2008
    Apopka, FL
    I have that exact fuel pump, and it's worth it, it makes installation much simpler and is defentally plug-n-play. no ghetto rigging involved with buying the pump seperatly and making it fit in the stock housing. i also haven't had 1/4 tank issues, but I'm also still on the stock K03.
    May 23 2005
    Tricities Wa
    Quote Originally Posted by blmlozz View Post
    Wich one do you have??
    How under rated are the walbro pumps? is it good for lets say 350 all wheel horses wich would be well beyond the rating of 400hp
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    On this Walbro pump: http://www.034motorsport.com/product...uf1msk3jt4f1e2 , Chris Tapp made 570whp...
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by Sigma 3 View Post
    I have the one with the ATP housing the OP is referring to. the walbro is a good, cheap pump. like most things you get what you pay for though, and I have read of it seizing before. I wouldn't want to try to max the thing, if You are looking at more than say a 2871 or small 30 series, I'd go look at a bosch 044 and be done with it, unless you go past 700HP.
    If there's one thing I've learned about modding from the past 3 years it's always build room for improvment.
    Jun 12 2005
    Athens Greece
    I have a Passat and I can assure you that the ATP Walbro+housing doesn't fit in the Passat due to a totally different basket.
    On an A4 it fits ok.Also an A4 will never ever face starving issues due to its basket and pump being plased in a "sump".Unlike the A4,tha Passat has the Golf Mk IV type of swirl tank.
    Now I hope not to go OT:
    For anyone interested to use the Bosch 044 in the A4,I have available a "drop in basket kit" bought from 034 MS , which is of no use to my Passat.I am keeping the pump which came with the kit and if you already got the pump I can supply the kit for cheap.
    May 23 2005
    Tricities Wa
    Quote Originally Posted by 317ssayzarc View Post
    I looked at that one jake but I want an in tank setup. Thanks though
    Oct 27 2007
    In the lab
    Then get the intank version, part number gss 340, thats what I have in my car
    May 23 2005
    Tricities Wa
    Jake does that fit into the stock basket?
    Oct 27 2007
    In the lab
    Yes it fit in mine... I got a foam sleeve that fits over the pump and then it drops in... Just be gentle with the basket, its fragile and the dealer will only sell a pump/basket assembly
    Jul 07 2004
    socal
    I didn't use the sleeve and had no issues.
    97 A4 2.0TQM
    Rochester, NY
    if you don't use the foam sleeve, the pump will bounce around in there since it's not in there snugly. I don't see how that could be a good thing...
