Results 1 to 18 of 18
    Administrator Four Rings
    Feb 10 2004
    Audis
    The Internet
    Post Audi AG: Paris Debut for Audi S4 with 30 percent CO2 reduction
    September 23, 2008 - Audi AG
    • High performance A4 model downsizes to more economical but no less exceptional six cylinder supercharged FSI engine
    • All-new S4 and S4 Avant models debut at 2008 Salon de l'Auto in Paris, running from October 2 to 19
    • Supercharged V6 TFSI with 333PS and 440Nm from 2,500-4,850rpm replaces naturally aspirated V8
    • Six-speed manual or optional seven-speed S tronic twin-clutch transmission that actually further improves fuel economy
    • Evolution of quattro system with active sport differential capable of varying torque not only between front and rear axles but also between each rear wheel
    • Optional Audi drive select adaptable dynamics system enables fine-tuning of throttle response, shock absorber settings and steering feel
    • S4 sedan 0-62mph in 5.1 seconds (outgoing S4 5.6 seconds), top speed limited to 155mph (outgoing S4 155mph), combined mpg 29.1 (outgoing S4 21.2mpg)
    Making its Paris Show debut next month will be a new Audi S4 that gives equally high priority to thrills and thrift thanks to a new six cylinder TFSI engine that not only decisively outperforms its V8 predecessor but does so with a 30 percent reduction in CO2 emissions and 29mpg-plus fuel economy.
    The completely new 3.0-liter V6 shares its 'TFSI' designation with the six engines in the Audi range that combine single turbo charging with FSI direct injection, but the newcomer actually bucks the trend by using the alternative method of forced induction - a compact supercharger chosen because it delivers keener response than even two turbo chargers could achieve.
    The supercharger's ultra-compact dimensions enable it to fit easily inside the 90-degree V of the cylinder banks, and as a result the gas paths to the cylinder are extremely short, resulting in throttle response that even a naturally aspirated engine of the same displacement can't match. With the compressor's help the new unit generates 333PS and a healthy 440Nm torque peak available from 2,500rpm right through to 4,850rpm, enabling an appropriate 0-62mph sprint time of just 5.1 seconds for the manual sedan (Avant manual 5.2 seconds). Top speed is limited electronically to 155mph. More
    Full Article
    Article Photo Gallery
    A4/S4 Wallpaper
    [email protected]
    Audizine - "For All Things Four Rings"
    Instagram: @audizine
    Twitter: @audizine
    YouTube: /audizine
    Merch: store.audizine.com
    Registered Member Three Rings YMJ's Avatar
    Feb 08 2008
    2001 Pearl White Audi S4
    Re: Audi AG: Paris Debut for Audi S4 with 30 percent CO2 reduction
    can someone please tell me what 333ps and 440Nm torque translates to in Horspower and Torque ft
    Pearl White B5 S4
    APR Chip~APR Exhaust~APR boost Gauge
    Bosch 710N DVs
    Koni Sport Shocks~Eibach Springs
    JHM Short Shift Kit~Bimmian Titanium Shift Knob
    RS4 Grill
    18'' RS4 Hyper Black Rims
    Interior Xenon Kit ~ 10 K HID Kit
    FREE 10SecS4!!
    Feb 10 2004
    2009 A4 2.0T Sedan
    The horsepower rating is basically the same thing, so 333 horsepower and approximately 325 ft lbs of torque.
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    So if the manual version sprints to 62 in 5.1 (or under 5 secs to 60), then the 7 speed S-tronic should be minimally faster, no?
    Senior Member Two Rings medracr's Avatar
    Mar 01 2004
    2006 A4 2.0T S-Line
    Los Angeles, State of Confusion
    So does the addition of a supercharger for forced induction open up the possibilities for relatively easy perfomance mods? Like, chipping,etc?
    "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways, Cuban cigar in one hand, martini in the other, body thoroughly used up, totally worn out and screaming 'WOOHOO! What a ride!' "
    -Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!- Jonan
    Jan 18 2008
    TX
    Damn the fuel economy sounds pretty good. 24mpg combined means about 30mpg out of a 333hp engine.
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by ibiski View Post
    Well the 7 speed dual-clutch S-tronic is heavier than a basic manual trans, but we shall see.
    Quote Originally Posted by medracr View Post
    Depends how much power Audi has already wrung out of the motor and supercharger. I'm sure there is some room for the software companies to play with as Audi usually plays it fairly safe.
    Veteran Member Four Rings Hamann's Avatar
    Oct 14 2006
    2017%20VW%20Touareg%20Executive%3B%202015%20S8
    Tampa, FL
    no way this thing gets 30mpg....
    2013 S4
    Feb 10 2004
    2009 A4 2.0T Sedan
    The spec sheet for a manual transmission B7 S4 sedan says 17mpg combined and not 21 as claimed in this press release. The V8's highway mpg, however, is listed at 21. So regardless, the mpg on this new motor is pretty damn amazing.
    Jan 18 2008
    TX
    The press-release wasnt using US mpg when it was talking about the old S4 specs. Only the B8 specs were converted.
    Feb 10 2004
    2009 A4 2.0T Sedan
    They've been converted at 24 mpg combined, whereas the B7's V8 is 17 mpg combined. So a 7 mpg increase over the old engine, while still pumping out 333HP, is damn impressive.
    Jan 18 2008
    TX
    Hope this holds true, mpg is the only reason i would want the 2.0 instead of the V6. Now i can get the total audi package!
    Feb 10 2004
    2009 A4 2.0T Sedan
    Quote Originally Posted by amaurictx View Post
    Same here. I'd ideally want an A5 2.0T, but since that won't be an option here for us (for awhile) I was going to opt for a new A4 2.0T. But if the new S4 is going to be that efficient, damn...
    Veteran Member Four Rings DELUX's Avatar
    May 28 2004
    04 A4 USP 1.8TQ M6 Ultrasport
    Asheville, NC
    The RS4 is rumored to be a beefed up variant of the same V6, so this could be very much like the B5S4 where everybody and their mom was doing quick and easy RS4 upgrades.
    USP CLUB MEMBER #3 - 2004 Audi A4 1.8TQ6
    Veteran Member Three Rings ColinAndrews's Avatar
    Oct 29 2007
    Edmonton, Alberta, Canada
    I think it looks fabulous in sprint blue, and the images make me so dissapointed that the S4 Avant is not coming to North America.
    Mar 09 2008
    Dubai, UAE
    Quote Originally Posted by DELUX View Post
    Yeh....I started that 'thread of a beefed up V6 from S4, for the RS4'.
    It was all speculation. Speculation suggest, the upcoming RS4 is more likely to get a NA or FI V8 rather then the 'beefed up SC V6' from the S4.
    Anyway, the RS5 is going to be revealed soon......so whatever RS5 gets , the RS4 will get it too:D
    05 Honda Accord V6
    May 28 2004
    Asheville, NC
    Quote Originally Posted by Obi_agent View Post
    Totally not true. The S5 and the S4 don't have the same motor do they? And it wasn't from your thread, it was from an article I read on Fourtitude.
    Good numbers! Forced Induction generally leads to a car that can have some serious power upgrades relatively cheaply. I guess we shall see if that holds true with this S4.
    The B5 S4 is a super value right now... you can get a 400 crank hp car for $13k if you look hard enough!
