Results 1 to 13 of 13
Thread: Mp3 + cdr issue
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    Mp3 + cdr issue
    So i put a few cd's onto my mp3 and it will only play the first folder. Each cd is in it's own folder.
    How should i be burning the mp3 cd? Also is a there a special way to go through the folders? cause i couldn't figure it out unless i burnt the cd wrong.
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Aug 08 2008
    2017 Q5
    Houston, TX
    Re: Mp3 + cdr issue
    well, the way that I have mine working is that I burn the CD as a DATA CD. Not an actual MP3 cd. then you just use the browse function. it would be the same button as the CD 6 or CD 12 button when going through the different stations/cd's(ipod connected) you may have. hope this helps.
    you should also be able to go through the folders and pick individual songs to play while still listening to whatever song your on...as long as it is on the same cd. word.
    Apr 14 2008
    Milton VT
    Re: Mp3 + cdr issue
    yea i burnt the cd as a data cd not mp3...i just called it mp3 cause that's all that's on there. I was only able to play the first folder.
    Mar 17 2008
    2007 A4 2.0T Tip
    arlington, Va
    Re: Mp3 + cdr issue
    Quote Originally Posted by vtracer20 View Post
    First off, an mp3 cd and a data cd are the same exact thing. Im not sure how your folders are set up on the disk. When i first made the data cd i had a first folder for the artist and then within each artist folder i had different folders for each of the artists albums. This did not work. The directory would like this "Artist\albums\songs"
    Now the cd is set up to only list each album and works perfectly. The directory looks like this "Albums\songs"
    So Artist\album\songs wont work
    Albums\songs should work.
    Hope that helps
    Apr 15 2007
    WNC
    Re: Mp3 + cdr issue
    This owrks on the standard headunit?
    2013 RS5, 2014 Q7
    Mar 17 2008
    2007 A4 2.0T Tip
    arlington, Va
    Re: Mp3 + cdr issue
    Quote Originally Posted by rnp614 View Post
    symphony II 6 disc in dash w/ mp3. Im pretty sure that is standard. I dont have the nav but i do have Bose.
    Apr 14 2008
    Milton VT
    Re: Mp3 + cdr issue
    you have to have the synphony II +, the one with the large screen, 6cd player. I'll try what you just said, thanks
    Mar 17 2008
    2007 A4 2.0T Tip
    arlington, Va
    Re: Mp3 + cdr issue
    yea exactly
    2007 A4 2.0T Tip Black on Black
    -35% tint
    -debadged
    -black out side markers
    -black out grill
    -red led dome/footwell bulbs
    Established Member Two Rings Who Needs 8's Avatar
    Aug 01 2008
    2006 A4, 1989 Turbo Trans Am
    Dallas, TX
    Re: Mp3 + cdr issue
    I asked this in a previous post and got no response:
    Can the Symphony II+ be interchanged into a '06 that has the older Symphony II?
    Mar 17 2008
    2007 A4 2.0T Tip
    arlington, Va
    Re: Mp3 + cdr issue
    Quote Originally Posted by Who Needs 8 View Post
    not exactly sure, but i dont see why not. They should just be pretty much plug and play. I would ask in the telematics forum.
    Apr 14 2008
    Milton VT
    Re: Mp3 + cdr issue
    yea i would assume it just plug n play
    Veteran Member Three Rings grizzles's Avatar
    OC, CA
    Re: Mp3 + cdr issue
    Quote Originally Posted by MYaudi View Post
    Yes, I have one in my 06. You need a couple adapters though. It's kind of expensive all said and done but it was def worth it for me.
