Thread: fmic question
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    fmic question
    I just installed a ebay fmic about a week ago. My question is it sopposed to make a loud whistling/ sucking in noise when boosting? All my clamps are on tight I made sure of that. I will post a video later!
    10 b8 s4 6MT sprint blue / black & silver
    Jun 14 2007
    2000 S4
    Connecticut
    Re: fmic question
    i had the same thing, and i had people tell me that its because the piping is aluminum that you hear air rushing.... bottom line is somewhere, you are losing air... i had the FMIC for like 3 months before I got out of it because it was so annoying haha. But no, you shouldnt hear and kind of whistling. check the silicon connectors for any rips, if you used T bolts, if you over tightened you could of bent the pipes etc.
    Oct 31 2005
    Ashburn
    Re: fmic question
    No it's not suppose to. But does it boost fine? Might want to pressure test as leaks/blowing off hoses are common with this setup.
    - Instagram: @Sinister_rs5-
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Re: fmic question
    Check the chinese ic core for leaks, to do this u will have to measure the psi before the cooler and then after, if its more then 3-4psi i would send the cooler back
    Nov 07 2007
    New York City
    Re: fmic question
    thanks for all the responses, btw my car seems to be boosting fine I will pressure test and post a video tomm.
