Figured I would run this by the B5 guys since its the same brake setup and there is more of you on here than C5 owners..
I already have drilled rotors & Hawk HPS pads with the stock HP2 calipers. They don't cut it. And my Z has Skyline GTR brakes (13"+ rotors and 4 piston calipers w Ceramic pads) so it set the bar a bit high for "good brakes". Had my heart set on the 6 piston Porsche kit from ECS cause it's simply gorgeous.. But after printing the fitment template, it doesn't fit behind either set of 18s I have.. So I need other ideas. My credentials are a minimum of 4 pistons, hopefully 14" rotors, but as close as possible, and a reputable brand. I liked that the Porsche kit from ECS took regular Porsche pads. So there were many pad options and they are readily available from any source.. That was also a big plus in case "Brand X" stops making their A6 brake kit and I am left without brake pads.. And the 4 piston kit from ECS is still a stock size rotor. No way I am spending all that money and still having a stock size rotor. Minimum is 13", but as close to 14" as possible...
Give me what ever feedback on brake kits you can. So far, I am leaning towards the 14" Rotora kit as long as it will fit. I have heard some people were not happy with StopTech, and Ksport. Plus Ksport is a brand I have not really heard of. This is brakes, so I want something with a good history.
So what to you guys recommend? Rotora, StopTech, Ksport, ECS 4 piston? Who has what & what do you think?
