Results 1 to 13 of 13
    Active Member Two Rings b5s415's Avatar
    Sep 22 2008
    01 S4 x2
    California
    2001 S4 oil leak
    Hey everyone I have a 2001 S4 and I have an oil leak. I think it's the valve cover gasket on the driver side. Im going to change it this weekend, but I just wanted to know is there anything else I need to replace, like timing tensioner seal, suction pump etc? I know it's a newbie question but I just want to make sure I have all the parts before I start the job. It doesn't look like the tensioner seals are leaking, but I wanted to know if its a good idea to replace while I have the car apart. Any help would be great.
    Thanks
    Re: 2001 S4 oil leak
    jsut do all the seals to get it over with
    4x cam seals
    2x cam plugs
    vavle cover
    front crank seal,
    upper and lower oil pan
    rear main seal
    timing belt components
    in fact just pull the engine out while your at it, if you plan on keeping the car learning to pull the engine, by yourself, in less than 5 hours is essential, believe in 1 year of ownership, i have pulled the engine 3 times and had to drop it down 2x more.
    just do it now and get it over with :)
    and you better replace those turbos or else the valve cover gaskets wont work right
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Hey man, welcome to Audizine. Be patient. someone will answer your question for you without being a smart a$$. It drives me crazy seeing how people treat new users. Its a wonder anyone joins az anymore. We are not all like that, just keep that in mind.
    If I knew the answer to your question I would answer it. But Im not sure about what to replace. The one thing I do know is audi's are known to leak oil but you already have experienced that. lol
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Sep 22 2008
    01 S4 x2
    California
    Thanks for not being a moron like goohead. I thought it was a pretty decent question, should I just go ahead and change those seals or leave them alone since they aren't leaking? Anyway and real help is appreciated. Thanks
    Senior Member Three Rings wasup0818's Avatar
    Dec 07 2005
    US
    depend on the labor unless u gonna perform it urself.i will just replace it for now unless the leak is so bad. once u start u will never stop..i m experience some sort of leaking as well on my s4 but i havent really get it check out yet. i hope it just some minor leak like the valve cover which my buddy said he can change it in an hour to 2.anyway good luck
    wow i was trying to help you out, cause your gonna have to get those done but nevermind i guess, have fun with the "car apart" with that one valve cover off
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    For the valve cover gasket, I would change the cam chain tensioner at the same time. The front cam seals, cam plugs, and front crank seal you’re not going to be able to do unless the car is in the service position (raised on jackstands in front with bumper and radiator housing off). If you want to change front cam seals, cam plugs, and front crank seal at the same time as the valve cover gasket and your timing belt hasn’t been changed yet and you have something like 50k miles, then I would say do timing belt change and change everything found in this kit:
    http://blauparts.com/proddetail.asp?prod=GF21002
    for the cam chain tensioner, you need this tool:
    http://blauparts.com/proddetail.asp?prod=N1A1016
    But you can just change the valve cover gasket and cam chain tensioner and you should be good. Check your cam plugs located on the back of the heads. They are these rubber looking plug things sticking off the back of the back. Just make sure they aren’t leaking oil too before you start your maintenance.
    Sep 22 2008
    01 S4 x2
    California
    I took a closer look at the car today, and it looks like just the driver side valve cover gasket is leaking. The cam plugs look good, as do the timing tensioner seals. I was just wondering since I will have the valve cover off if I should just do the timing tensioner seal as well. I'm going to do both valve cover gaskets since there is a little dampness starting on the passenger side. Everything else looks good. The only other thing I was thinking about changing was the suction jet pump, since I have heard that the failure of these can cause seals to blow and cause oil leaks. What do you think. Thanks again for all the help.
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    If you doing mind taking it apart again to re-do, then just fix what's broken. Though the other side will invariably go, as will the cam tensioner seals. Parts are pretty cheap, so if you're good with a wrench, i'd replace 'em all.
    --Adam
    Have questions? E-mail me.
    Sep 22 2008
    01 S4 x2
    California
    Quote Originally Posted by 1997gtx View Post
    --Adam
    Thanks. Im planning on doing the valve cover gaskets on both sides, since the passenger side is showing some signs of seepage. Im probably going to do the cam tensioner seals as well depending on how they look. But for sure Im going to do both valve covers. And possibly the suction pump, since this might be the reason that I have the valve cover leak in the first place. I will test the pump first to see if it needs to be replaced.
    Thanks a lot for the advice.
    Veteran Member Three Rings s4killer's Avatar
    Jul 27 2009
    audi s4 b5(sold( corolla 95 stick, jetta se, honda civic ex
    wisconsin
    hello friends I have a big problem I went to my garage and they told me I need a cam seal cost is $ 450 haora someone that I can explain it please the cam seal parts or you have not anything to seal has about this can help me understand this with photos and detailed information through
    s4 killer
    APR BI PIPE KIT
    APR SNUB MOUNT
    APR R1 DV
    RS4 MOTOR MOUNT
    NEW EGT SENSOR
    NEW KO3
    ST COILOVERS
    SAMCO HOSES
    Veteran Member Four Rings orttauq's Avatar
    Mar 11 2007
    8V S3
    tri state
    Quote Originally Posted by b5s415 View Post
    Bro, don't do the valve cover gaskets and not do the cam tensioner seals. When they start leaking in 6 months you have to do the same job all over again and then some, AND buy new valve cover gaskets.
    You're in there, just replace the cam tensioner seals.
    Senior Member Three Rings EtanClan's Avatar
    Jul 24 2007
    '02 Silver S4 6spd
    Lincolnshire, IL (Chicago)
    this might help you out btw:
    http://www.audiworld.com/tech/eng52.shtml
    Quote Originally Posted by goohead View Post
    and seriously? sorry but stfu man.
    '02 Audi S4 -- Stage II: silver on black, 6spd
