Results 1 to 8 of 8
    Established Member Two Rings A4donkey's Avatar
    Sep 24 2005
    Anywhere
    Help..... temperature low.....Help
    I've been frustrating about the funky temp gauge, below is the symptoms:
    -it keeps between 60 -80 degree C (ten O'clock) for the first 20 minute from cold start (it's summer here up to 34degreeC), when it almost reach 90C, then it drops back to arround 65-70 (ten O'clock)
    -after 30minute drive it can stay at 90C.
    - I can remember normally it takes 5 minute to reach 90C (12 O'clock)
    I have changed the green coolant sensor( 2days ago),top up and bleed the coolant system, but still the same.
    She just arround 30K miles, what is the possible cause and fix?
    Sep 24 2005
    Anywhere
    Re: Help..... temperature low.....Help
    I can feel it , there must be something wrong with the thermostat.
    Anybody can tell me, the A4 1.8T thermostat is electronic control or mechanical control (drive by heat)?
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    Probably the coolant temp sensor sensor. Easy enough to replace yourself for about $25. There's a write up on A4mods.com
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by gdawg'05a4 View Post
    Yup, green coolant sensor on the back of the head
    May 03 2005
    Boston
    Quote Originally Posted by A4ringedONE8T View Post
    Yeah, I had a fun time replacing that. Stupid retaining clip kept falling out of place and not much room to work back there.
    EPL S2 + TCU
    Previous Cars:
    Feb 17 2005
    Sarasota, FL
    You can thank the SAI system for that!
    May 03 2005
    Boston
    So when I replaced it (mind you, I finished about 12am), I thought it was good to go. Took the car out for a drive to make sure that the coolant temp sensor was ok. About 5 minutes into the ride, the needle starts rising to hot and there's a lot of white smoke coming out from under the car! The clip wasn't in all the way and the sensor popped out a bit spewing coolant out.
    Luckily I was next to a 24 hour supermarket and had a large parking lot. Let the car cooled down and then fixed it. It was in the mid 30s outside so my hands were freezing while trying to put the sensor back in.
    EPL S2 + TCU
    Previous Cars:
    Sep 24 2005
    Anywhere
    I did change the coolant temp sensor but no help, temp still at arround 70 degree and which took 40min of driving to reach 90 degree.
