Results 1 to 14 of 14
    Veteran Member Three Rings trautob's Avatar
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    Exclamation RADIO 100% DEAD help
    I had my car off for 8 days. I went to turn it on today and the radio is completely dead. No light or anything from it at all. Fuse on back of radio is intact, and the 20amp on the side of the dash is good as well. So I dont understand why it wouldnt be working if all the fuses are good and I didnt touch anything at all. please help..
    Registered Member Two Rings
    Aug 11 2008
    2003 Audi A4 1.8T
    Plymouth, WI
    Re: RADIO 100% DEAD help
    i got a stock symphony radio for the b6 a4 i could sell it to you for cheap. pm me.
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    try disconnecting the battery for a min then running it back up
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    id like to fix this one first before I buy another. How would disconnecting the battery help? Would it like "restart" it?
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    Jun 30 2007
    Raleigh, NC
    i know this is going to sound really weird -- but check ALL your fuses.
    odds are another one is blown, and that's causing the radio to not work. It may be something stupid that you don't use either. I had a blown home link fuse once and my headlights stopped working - go figure
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Jun 06 2008
    Long Island, NY
    Disconnecting and connecting right back will cut power to all electrical fuses and all. I had the same problem I disconnected my battery and removed the fuse then connected back up install the fuse again and the radio was back and running.
    Dont kno if that should help GL
    -Joey aka Chappy
    Tastefully Modded
    Veteran Member Four Rings Howard Hughes's Avatar
    Feb 17 2004
    1.8T Revo3 Q-Tip
    Chicago Illinois
    You can pull the radio fuse out and put it back in... it's worked twice for me when I had a stock radio....
    789whp
    Mar 11 2008
    B7RS4 & e46Ms
    I'm pretty sure (90%) that there's a fuse on the back of the headunit as well. Along with two other radio fuses in the driver's side fuse box.
    It may sound dumb...but also, try just holding down the 'on' button... I've seen it happen.
    Senior Member Three Rings Jbone29's Avatar
    Feb 25 2008
    Audi a4 avant
    Boulder, CO
    Quote Originally Posted by B6Lovin View Post
    I agree, iv had stuff like that happen. I would also recommend swapping the fuses, just because it looks fine doesn't mean it is!
    BTA4-**-Sold
    Current 08 STI
    **CU Sport Car Club
    **Avalon Motorsports
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    thanks for all you're guys input. I actually went down to the dealer and one of the techs let me borrow his radio removal keys. So i took the double din out, its the 6CD one and I looked at the red fuse on the back bottom and it was in tact. So I'm going to take off my battery and let it reset and we will see what happens. thanks
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    Quote Originally Posted by b6lovin View Post
    i Know This Is Going To Sound Really Weird -- But Check All Your Fuses.
    Odds Are Another One Is Blown, And That's Causing The Radio To Not Work. It May Be Something Stupid That You Don't Use Either. I Had A Blown Home Link Fuse Once And My Headlights Stopped Working - Go Figure
    You Got Pm!!!!!
    FlexTuning
    Amulet 1.8TM
    BAT#46
    Feb 27 2006
    Audi A4 1.8T B6
    Newport Beachhhhh
    so I unplugged the battery took the fuse out, then I plugged battery back in and put the fuse back in. I could hear the 6CD system making noises like its loading discs, but still the sound and LCD are off. Any other suggestions before I hand my car to the stealership, its either going to be something faulty like a wire, but I see them having me buy a new radio at $1,200 or some crappp.
    Registered Member Two Rings jaketone's Avatar
    May 26 2008
    ABC
    check your ground wire.
