Results 1 to 12 of 12
    Veteran Member Four Rings jbrown7815's Avatar
    Mar 12 2008
    Portales, NM
    Camber Issues, help!
    So I am slammed on Koni Coilovers. I have 19" wheels.
    Been running BFgoodrich KDW2s... 235/35/19s
    Well the inside of my rear left tire is THREADED bad. Like I probably shouldn't drive much more..
    My right rear looks fine.
    How can I fix this, prevent more?
    tires prolly have 10-15k max...
    thanks!
    edit: pic for reference
    Senior Member Two Rings KevinA41.8T's Avatar
    Nov 30 2005
    CONNECTICUT
    Re: Camber Issues, help!
    well obviously your alignment is off so you should start there.
    2000 S4 IMOLA - CCW CLASSICS 18X9 18X10 - STASSIS TRACKSPORTS 700/800 - ASP DTS - STERN MOUNTS - 034 DP'S - ASP TRU DUAL - CUSTOM INTAKE/CATCH CAN - VAST METH - AEM WIDEBAND - RS4 INTERCOOLERS - JFONZ TUNED
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    dont see what that pic proves
    Is that tire slanted in REAL bad?
    If not that, MOST LIKELY, the rear toe is off.
    Toe is the #1 tire-killer
    -Sami-
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    did you do an alligment after the coils were done.
    Mar 12 2008
    Portales, NM
    I don't have pic of wear right now.
    Yeah didn't get an alignment after getting tires put on. Figured that was issue.
    Senior Member Three Rings zcrew's Avatar
    Feb 15 2007
    2014 Tacoma
    Atlanta
    Even after I got an alignment my front camber was a little off. Just keep rotating the tires for best wear. And go to a place that knows what they are doing.
    Senior Member Two Rings inaforest's Avatar
    Sep 10 2008
    is full of junk.
    Los Angeles, CA
    I have been having the same issue. The rears come with stock camber adjustments, but the fronts only have stock toe adjustments. No one besides KMAC makes anything to adjust front camber, but I haven't heard any good things about that company.
    Let me know what you find out and I'll keep you posted cause I just put goodyear eagle f1's on my car and really don't want to lose them as quickly as I did my previous tires.
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Get an alignment. A large portion of wear issues associated to camber are actually caused by toe-in.
    -Darrick
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Your extra low ride height is exacerbating the camber problem as well. +1 on the alignment as it's $ extremely well spent IMHO.
    Mar 12 2008
    Portales, NM
    What's a good price to pay for an alignment?
    Veteran Member Four Rings BOPOH's Avatar
    Oct 08 2007
    Columbus, OH
    i just got both of my audi's alignments paid $80 per car, but i got it done at Tuffy
    Feb 15 2007
    2014 Tacoma
    Atlanta
    I had one at a well trusted tire/alignment shop near me and it was 120. It's hard for me to trust anyone, so I researched a ton before taking it anywhere and only felt comfortable there.
