Results 1 to 7 of 7
    Feb 01 2008
    Miami, FL
    ScheerSpeed Detailed: Mercedez-Benz CLS63 AMG
    This car belongs to the owner of 360FORGED wheels. it has around 20K miles on the Odometer, and has never seen even a wax job in it's life. however it is washed 2 times per week by a mobile wash guy. my job here was to bring it to better than new status. i was not looking forward to the ceramic clear coat...
    Exterior
    -Wash
    -P21s TAW pre-soak
    -CG CWG
    -white shMITT
    -Wheels
    -CG CWG
    -EZ detail brush
    -Swissvax wheel brush
    -OXO tire scrubber
    -white shMITT
    -ARO (tires)
    -Wheel Wells
    -Simple Green
    Clay
    -Special Yellow Clay :) (you know...)
    -ONR lube
    Engine
    -P21s TAW
    -Meguiar's Hyper Dressing
    Polishing
    -Exterior paint
    -2000 grit sanding paper
    -M105 via Purple Foamed Wool @ 1500RPM (2 passes)
    -Menzerna 106FF via blue sonus pad @ 1500RPM (1 pass)
    -Makita 9227C
    -3M backing plate
    -1000w halogen lights
    -ISA 50/50 wipedown
    -Wheels
    -1Z Chrome Polish
    -Exhaust
    -1Z chrome polish
    -#0000 steel wool
    LSP
    -Exterior Paint
    -CG EZcreme glaze
    -1Z Glanz Wax
    -FK1 # 425
    -Wheels
    -Swissvax Autobahn (2 coats)
    -FK1 # 425
    -Optimum opti-bond tire gel
    -CG Barebones (wheel wells)
    Extras
    -Stoner's Invisible Glass
    -1Z Glass Polish
    -1Z Gummi Pflege
    Interior
    -CG Leather Cleaner
    -1Z Cockpit Premium
    -Zaino Z10
    Here are the pictures of the car before i touched it. i arrived at 8:30AM and got right to work.
    The exhaust pipes were going to need some attention.
    The brake calipers were covered in grime. it had the consistency of grease
    the engine wasn't too dirty...
    I washed the car with P21s TAW and Chemical Guy's Citrus Wash n Gloss. then clayed the car with the "special Yellow Clay" using Optimum No Rinse for lube. after i did that i pulled the car into the sun to check out how bad the swirls and scratches were.
    Detailing in the Miami/ Ft. Lauderdale Area
    Feb 01 2008
    Miami, FL
    Re: ScheerSpeed Detailed: Mercedez-Benz CLS63 AMG
    There were a few pretty deep scratches which needed sanding in order to remove them. this is an example.
    The result from M105 left the paint pretty glossy!
    After Polishing with PO106FF
    one side of the exhaust pipe polished with 1z chrome polish and #0000 steel wool
    with the exterior finished it was time to move onto the interior. the leather was full of body oil, and the steering wheel was full of grime from mechanics who had worked on the car. here's the before shots.
    now im finally finished for the day at almost exactly 2AM
    the next day i went to the 360FORGED shop to take final pictures of the car.
    Feb 01 2008
    Miami, FL
    i also cleaned up the mufflers and exhaust pipes
    And the Finished Interior
    and the finished engine
    Feb 01 2008
    Miami, FL
    Thats all for this one! i hope you enjoyed looking at the pics!
    if you are interested in having any work done to your car, feel free to contact me with any questions you may have.
    thanks for looking!
    Scheerspeed
    and coming soon.... (mid-late october)
    be on the lookout for that detail!
    Veteran Member Three Rings TapouTx914's Avatar
    Apr 01 2008
    Yonkers, New York
    looks great looks like you do some real quality work. That car looks so nice haha
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    ^^^Support Tap Out..
    That detail came out wonderful as usual. Getting all the ASR cars huh. Looks like that CLS had some work done to it, wonder what he is pushing to the wheels.
    Train Hard, Go Hard, But always be Humble.
    Feb 01 2008
    Miami, FL
    thanks guys!
