Results 1 to 8 of 8
    Registered Member Two Rings
    Sep 16 2008
    2008 Audi A4 MT6
    Florida
    CAI & DV Questions...
    Ok...I am completely new to this so please have patience. I am looking to get a Carbonio Intake. I was told that I should also invest in Forge Diverter Valve. Is this true? What exactly does the DV do and what are the benefits of having it? Thanks for your help!
    Sep 02 2008
    Boston, MA, USA
    Veteran Member Three Rings outlaw77's Avatar
    Jun 19 2007
    2010 Camaro SS/RS 6.2 V8 Inferno Orange Metalic 400rwhp 400tq
    Langley BC Ca.
    Re: CAI & DV Questions...
    forge dv maybe. But I wouldn't because you have an 08 A4 so you should have the updated version of the stock dv in which case your fine if your stock. When and if you get chipped, maybe get the forge dv. the cai is a waste of money. Just get a k&n filter if that.
    07 Ibis White S-Line 6smt - APR 93,91,89 - APR snub mount - 19" Sportec Mono 10's - H&R springs - RS4 rear sway - RS4 pedals -
    Sep 16 2008
    2008 Audi A4 MT6
    Florida
    Thanks for the feedback and links...very helpful.
    The cai doesn't do much? That is surprising!
    Aug 08 2008
    2017 Q5
    Houston, TX
    would you recommend the drop in or the cone filter?
    Jun 19 2007
    Langley BC Ca.
    drop in filter. cone if you make a good heat sheild.
    Veteran Member Three Rings Kevin2772's Avatar
    Apr 17 2008
    Cincinnati
    I dont think either of those will do anything for you that you'll notice. Just get the chip. Then the Forge DV. then the CAI....
    03 BMW M3 Convertible
    13 A4 2.0T 6MT Premium Plus (Gone)
    08 A4 2.0T 6MT S-Line Ti.Pkg / APR 93oct. Tune / Forge DV (gone)
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    go buy a chip and a k and n cone filter. save your money on the other stuff. youll get the power and sound you need with these two. then, if your dv goes, let them replace it.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
