Results 1 to 3 of 3
    Veteran Member Three Rings hyperplus's Avatar
    Sep 29 2004
    Milwaukee WI
    Question Neuspeed Exhaust gasket size?
    Anyone knows the size for the middle joint of the Neuspeed gasket?
    thanks
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Neuspeed Exhaust gasket size?
    Should be 2.36" like the DP opening. Hard to find mm sized gaskets unless you buy them online. I don't think you'd have any problem running a standard 2.5" gasket there though. You can buy universal 2.5" opening gaskets at any of your local auto parts stores...
    Sep 29 2004
    Milwaukee WI
    Thanks. I will check out the 2 1/2 size.
