Results 1 to 19 of 19
    Saint Cloud, Fl
    Stupid Internal Wastegate
    I am now in the market for a new 71R eliminator. I installed this turbo months ago. It worked great for a day. Since that day i haven't been able to boost over say 14lbs.
    - I intially thought that I had a boost leak. not so much
    - I then suspected that it might have been my EBC. not so much
    - So I unplugged the wastegate and still only got 14lbs of boost. winner
    So based on the gathered information and my non professional skill level, I think that my internal wastegate is shit !
    instagram ------------> low_enforcement
    Feb 17 2005
    Sarasota, FL
    Re: Stupid Internal Wastegate
    That doesnt mean your turbo is shot. Hook an air compressor line to the wastegate, turn the regulator down to 20psi and see if you can hear the wastegate opening when the pressure hits it
    Saint Cloud, Fl
    I shot air into it and i could hear it open and close. Im not sure what psi it was at though, my friend didnt have a pressure regulator on his pump.
    Feb 17 2005
    Sarasota, FL
    No reason it shouldnt be working then ... check your EBC
    Dec 03 2005
    2 pedals 1FG
    connecticut
    What is the p/n on your wastegate actuator? I wonder what spring is in that actuator. My GT2871R is set to 11psi.
    When you disconnect the actuator can you move the arm freely?
    Is the actuator rod fairly snug with the wastegate arm? If that is loose you'll be leaking and won't be able to boost above a certain amount.
    -Doug
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    Sounds like you need to adjust the tension on the wastegate rod so that it'll take more pressure to swing it open.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Nov 13 2007
    02 A4 3.0QM, 84 Rabbit GTI
    Gaithersburg, MD
    How did you confirm you don't have a boost leak?
    With the wastegate disconnected, you should be making crazy boost unless you have a lot of backpressure, a charge system leak, or possibly a bad turbo.
    The only ways the internal wastegate could be causing a low boost scenario is if the spring is too weak (probably not the case) or if the flapper valve isn't seated correctly or if the actuator is binding and not returning to a fully closed state.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Splattj View Post
    That is where I was going with my questions....
    -Doug
    Saint Cloud, Fl
    Im not sure what the part # is. I forgot to add that I build boost really slow. The EBC is working properly. I even tried this with a Forge MBC. Same end result
    Saint Cloud, Fl
    Quote Originally Posted by RLB6 View Post
    The rod tension is all the way tight. I really dont know what else it can be. My IE block off plate will be here by thursday and Ill remove all of that vac line crap as a last resort before pulling the turbo.
    Nov 13 2007
    Gaithersburg, MD
    If you can reach it, disconnect the rod and see if the valve moves freely on the exhaust housing. If it's binding or doesn't feel like it will close all the way, you may have to pull the turbo to resolve.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Eliminator comes with a 1.0 bar wastegate spring (14psi). I find it best to use a pump to adjust the manual boost controller.
    A bulb pump from a blood pressure cuff works great, along with your boost gauge.
    Saint Cloud, Fl
    Quote Originally Posted by 400HPA4 View Post
    Yah Im getting around 14 psi at best. Even when I plugged in a MBC I still got 14psi. Im kinda at wits end because I dont know what else the problem could be.
    If the internal wastegate is 1 bar, there has to be a problem somewhere else right ?
    I followed the boost leak test thing on A4Mods and couldnt find a leak
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The leak may not be at the intake track, it could be at the turbo or the MBC itself, the easiest way to check the MBC is to connect the outgoing end to the boost gauge and connect the incoming to a air pressure source, you just do not want it to be to much greater than 30 psi or so, this will let you know how much air pressure the MBC is letting through.
    Saint Cloud, Fl
    Im using my EBC now, I took the MBC back
    Veteran Member Three Rings Trev's Avatar
    Nov 25 2007
    b6 a4tq, 95 Eagle Talon (Rip)
    British Columbia, Canada
    Weld it shut and get an external
    Saint Cloud, Fl
    welding it shut would still require having the turbo come off.
    - I really hate not being able to figure out whats wrong with my car.
    Jun 30 2007
    Raleigh, NC
    man that sucks.... cuz you can't get that back turbo bolt off with it on the car can you? (can't remember for sure, i just know that I bolted my turbo to my manifold FIRST then put it all in)
    either way that sucks man.. time to go bigger!
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Saint Cloud, Fl
    not gonna go bigger, prolly just replace it.
    - does anyone know what could cause your boost to build slowly ?
